Home > Puma (Tdci) > 2.4 Oil pressure warning light operation
Page 1 of 3 123>
4wd-junky
Hello again Very Happy
Can anyone please explain exactly how the Oil pressure warning light on a 2.4 operates?
I have studied the electrical wiring diagrams and it appears the oil pressure switch is connected to the warning light in the instrument cluster via the ECM.
When started from cold the oil light goes out immediately, but if I switch the engine off after a few seconds running and restart it the light takes a little longer to go out after the second start. To me this does not make sense as the oil is still cold.
I'm thinking the ECM/IPAC is delaying turning off the oil light on the second start.
Has anyone also noticed this?
Post #637629 15th Jul 2017 12:35pm
4wd-junky
Over 70 views and no response Shocked
Maybe I should just be happy the light always goes out Thumbs Up
Post #637979 17th Jul 2017 2:29pm
ericvv
Post #637996 17th Jul 2017 3:38pm
dorsetsmith
if you think have problem use oil presser gage and check the oil presser
workshop Manuel below
https://1drv.ms/b/s!AtZSoWFHDgnGhQoLf-ZCjkI5M0R7
Post #637999 17th Jul 2017 3:59pm
4wd-junky
Thanks Eric, that's interesting and makes me think I probably need to investigate this further.
Thanks dorsetsmith, that's a good idea, will need to invest in a gauge.
Also, I've been thinking about connecting a temporary warning light directly to the switch in the conventional way to test if the ECM was actually causing a delay.
Post #638021 17th Jul 2017 5:15pm
Thon
If I start mine using the glow plug sequence the light goes out immediately. If I skip the glow plug sequence and simply start it, and I also get a delay.
AFAIK the oil pump is entirely mechanical so the likelihood is that it is not an oil pump problem.
Post #638113 17th Jul 2017 10:09pm
4wd-junky
Thanks Thon, that's what I'm seeing. Thumbs Up
It's like the ECM/IPAC is doing other things before it decides to turn out the light.
From the manual:
Low Oil Pressure Warning Indicator
The low oil pressure indicator is controlled by the instrument cluster software and illuminated on receipt of a high speed
CAN bus message from the ECM. The indicator is illuminated in a red color when the ignition switch is turned to position
II. When the engine is started and the oil pressure increases the low oil pressure indicator should extinguish. If the
indicator remains illuminated or illuminates when driving the vehicle should be stopped at the earliest opportunity and
the engine switched off until the fault is rectified.
Post #638118 17th Jul 2017 10:28pm
Thon
Forgot to mention that if I skip the glow plug sequence the glow plug light also remains lit with the oil pressure light, and extinguishes at the exact same time as the oil pressure light.
I think it's just an anomaly of the instrument, and not indicative of low oil pressure.
Post #638146 18th Jul 2017 5:55am
Naks
I have not ever seen what the OP describes in my Puma, despited various types of restarts - hot, cold, medium, etc.
Check oil pressure sensor and connections?
Any faults appear during a scan? --
Post #638154 18th Jul 2017 7:29am
Thon
It's not to do with the temperature, it's to do with the starting sequence.
If you wait for glow plugs light to go out, then the oil pressure light extinguishes as the engine fires.
If you skip waiting for glow plug sequence, the glow plug light and oil pressure light remain on for a second after the engine fires.
No fault codes stored.
I don't believe it is a "real" fault as the oil pump is entirely mechanical - it's just an anomaly with the way in which the instruments work. It's so consistent on my 110 with the starting sequence I just ignore it.
Some might call it character .... Laughing
Post #638157 18th Jul 2017 7:52am
4wd-junky
Thanks again Thon and Naks
I wonder if the different low oil pressure warning light operation behaviours are software revision related?
Post #638178 18th Jul 2017 9:13am
Thon
I think it is entirely possible that it's software, but as mine has the latest available since it was serviced in March I don't think it's a known problem with a developed solution.
I just ignore the anomaly during starting but once running would obviously take notice and act accordingly should it light up.
Post #638193 18th Jul 2017 9:52am
Naks
Just a note that when the oil pressure light comes on, it might be too late for your engine.
Rather fit an engine monitoring system like Madman, so that you can see the actual oil pressure in real-time. You can then set an alarm if it dips below 1.0. --
Post #638195 18th Jul 2017 9:58am
4wd-junky
Thanks Thon ....... I agree Thumbs Up
It's amazing how something as simple as a low oil pressure warning light can get over engineered to the point it's operation is misleading Rolling with laughter
Post #638198 18th Jul 2017 10:02am
Thon
Of course it might already be too late, but it's better to have the light than waiting for a rod to appear through the bonnet Smile
IIRC PUMA 2.4 motors are no more susceptible to oil pressure failure than most, and there was a story on here recently about an ex-development engine taking 30 miles to seize when run without any oil.
It's not a pleasant situation to be in but a full crank seizure happened to me in our Subaru, on the A34 at 70 mph in the 2nd lane so i'm thinking statistically it's unlikely to happen to me again. Oh, and the same car did exactly the same to my wife on the A303 3 months later after it was "repaired", so i'm doubly covered.
Post #638199 18th Jul 2017 10:12am
Page 1 of 3 123>
