Home > Puma (Tdci) > Lumpy idle
Page 2 of 4 <1234>
dgardel
Italy
ROBBONTHEROCK wrote:
I found on the web a denso training manual which goes into deep discussion on the Denso HP3 system, which is what is on a 2.4ltr duratorq.
Link? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #637485 14th Jul 2017 1:33pm
Naks
how long can one run a faulty VCV, and are there any long-term issues?
reason I'm asking is that my indie can only attend to my Puma in August, so still 3 more weeks to go Neutral --
Post #637488 14th Jul 2017 1:55pm
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
Link?
http://steldiesel.ru/files/crdensoservismanual.pdf
http://www.yildiz.edu.tr/~sandalci/dersnotu/AKTraining.pdf
Note the pump on denso website refers to HP3
Worth a read, my diesel engine knowledge is based on 90's plant engines, so relatively unsophisticated. The common rail system is fascinating.
I originally set-out to understand if the SCV or VCV was effectively an electronic throttle, but its not that at all.
All it does it removes parasitic loads on the engine by reducing load on the injection pump when full fuel is not required. I.e. don't waste energy heating and working fluid that is essentially unused.
brilliant stuff Smile
Andy
Post #637522 14th Jul 2017 6:55pm
churchy
2007 Defender 110 Puma 2.4 XS CSW Java Black
Thanks Andy - I too hVe a roadtrip to Europe coming up so need to get the issue sorted before setting off.
Would a faulty vcv be causing the egr to be noisier and cycle more on road and when when switching the engine off?
Post #637837 16th Jul 2017 6:45pm
ROBBONTHEROCK
Hi,
I'm really not sure. I would ask one of the forum experts, who work on these for a living.
But from my understanding, the VCV being faulty shouldn't cause the erg to fail, and vice versa
But it seems the erg and the vcv seem to have similar lifetime's.
I suspect failure on either (seals passing on EGR) would not help and with both weak at the same time it would probably feed off each other.
Andy
PS for what its worth, I'm getting vcv and erg done at same time.
Post #637911 16th Jul 2017 11:17pm
dgardel
Italy
Link?
Andy
Thank you Andy Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #637919 17th Jul 2017 4:57am
dgardel
Italy
No, but the engine can be a bit more noisy. I run 2 years without PCV learning procedure successful. After PCV changed, I was able to run the procedure without any issue
No relationship between the EGR and PCV Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #637920 17th Jul 2017 5:07am
Naks
Thanks dgardel!
I see on BAS' website that they recommend doing the VCV and/or Pilot Correction learning on 'standard non tuned' engines - why wuld that be?
Surely if you are running a BAS remap permanently, then these should be done while the remap is on? --
Post #637942 17th Jul 2017 9:32am
dgardel
Italy
Simply, using the BAS tool, first re-load the standard tune, then do the PCV learning Procedure following the BAS tool instructions, 3rd re-load the BAS Map Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #637951 17th Jul 2017 10:32am
Naks
thanks D, that makes sense for the VCV learn.
but it doesn't make sense for the Pilot Correction - if I look at the IID manual, it says the Pilote Correction learning is required when... "The engine ECU firmware is updated (or remapped)".
So surely one should set the map to factory for the VCV, and then load the BAS map, and then do the Pilot Correction? Question --
Post #637956 17th Jul 2017 10:36am
dgardel
Italy
I meant only for the PCV learning process. Pilot learning MUST be done with the remap loaded Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #638002 17th Jul 2017 4:07pm
Naks
great, thanks for clarifying!
Thumbs Up --
Post #638019 17th Jul 2017 5:07pm
Naks
Someone I know suggested that I do the VCV and Pilot Learning to see if these would solve the issue.
I returned the Puma to the factory map and re-did the VCV learn. I then re-uploaded the BAS map and then did the Pilot correction.
This morning the white smoke was not as bad as previous days, but it was also not as cold last night, so difficult to tell if there was any effect. --
Post #640086 27th Jul 2017 10:34am
Naks
gents, the VCV has been replaced and the pump relearn done, but the problem is still there.
What do I do now??? Big Cry --
Post #644819 18th Aug 2017 7:45am
Naks
Anyone?
If it is the glow plugs, how do I test this?
if it is the injectors, what readings can I look at on the IID tool to diagnose?
thanks for any help! --
Post #645610 22nd Aug 2017 9:23am
Page 2 of 4 <1234>
