![]() | Home > Puma (Tdci) > Output Shaft |
| d.tribe Member Since: 11 Apr 2015 Location: hampshire Posts: 9
Hi all
I think my 110 has fallen victim to an output shaft failure. Started getting a loud clonk when taking up drive and within a few miles complete loss of drive and loud noises from gearbox/transfer box area. It's off to a local Indy tomorrow for diagnosis. Just wondered if it is the output shaft failure how much others have paid to have it sorted. Also thinking of getting the Ashcroft upgraded shaft fitted if that's what's failed. Wish I had extended the warranty now!!!! Dave. |
| lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1343
Given that this problem is well known and not isolated, I wonder what options exist to claim that the design is not fit for purpose and that repairs should be rectified by JLR regardless of warranty period? Do we have anyone on the forum who understands consumer legislation in this respect?
| AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242
I had mine changed recently for a new OME shaft with a bellows to contain grease. Wasn't prepared to go the Ashcroft way as I'm selling it anyway.
When I had a new transfer case under warranty I asked the workshop foreman to make sure this shaft was well greased....and his answer was "This is not a service item" in a deep brown curry nosh shop voice! And they obviously hadn't greased it as the shaft was as per the above pics. Friend had his 2007 Puma shaft let go after many thousands of kays of remote travel, luckily at a service station east of Perth WA and not in the bush far from help. He never reads forums as they're all doom and gloom...... he loved his 110 but haven't heard from him since this happened so suspect he went back to the darkside. 20 years with a Nissan which never faltered but eventually disappeared as rust had gone through most of it! AlanH. |
| zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720
But it is a TSB for just that problem. They're supposed to have been greased on assembly. |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18050
Alan, is this a typo for "OEM", or does Old Man Emu now make replacement shafts? |
None at all, I should think! In my experience JLR is not particularly receptive to this sort of thing unless ordered to do so on safety ground by the authorities or unless it is attracting such widespread negative publicicty that it is affecting sales. On a discontinued vehicle made in fairly small numbers, I can't see it happening. If someone's output adaptor shaft failed leaving them stranded on a level crossing in front of a fast approaching passenger train or a similar catastrophic predicament, or even if there was a demonstrable record of people dying in accidents resulting from shaft failure, you might have better chances of action. Bottom line is that unless it is a defect which is likely to kill or maim people, your chances are extremely small. |
It may well be on their TSB (whatever that is) but who knows what the assemblers bother doing until something breaks? By that time it's well away from them so why would they worry about that?
As far as I can see Ford made sure not a cent was spent on anything they could get cheaper elsewhere...... this shaft and axles, clutches, floor coverings etc. being prime examples. Mines for sale as I said and it has been a great reliable vehicle, but I've made sure as much as I can that things that might break have been fixed. Hopefully the D4 isn't made in such a fashion.... AlanH. PS. Twas a typo BW, while I woz in me cups ..... |
| proloForêt Member Since: 16 Mar 2017 Location: Montereau Posts: 248
Perhaps I am to be stupid here. Should the front wheel still have drive when this shaft fail?
I don't know but I think not. No doubt one of our experts will soon let us know.
AlanH. |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
No, this is the shaft that connects the main box to the transfer box so if it fails, all drive is lost. Darren
If the output adaptor shaft fails, you will have no drive at all, whether or not the centre diff is locked, but the handbrake will work (in effect it is just the same as being in neutral in main or transfer boxes and trying to drive off, but usually noisier).
If a rear halfshaft, diff, or drive flange fails (also a common failure) you will initially lose all drive, and you will find that the handbrake won't hold the vehicle. If you get an assistant to look under the vehicle as you let in the clutch with the footbrake applied, the assistant will see the rear propshaft rotating. Locking the centre diff in this event will give you both drive and handbrake. If a front halfshaft, diff, or drive flange fails (not quite so common a failure) you will again initially lose all drive, but you will find that the handbrake will still hold the vehicle. If you get an assistant to look under the vehicle as you let in the clutch with the footbrake applied, the assistant will see the front propshaft rotating. Locking the centre diff in this event will give you drive. |
Technical Service Buletin. They're sent out to dealers to make them aware of changes in procedures, fixes for common faults or possible errors made on the production line. The shaft was supposed to have been greased on production, but many werent, so dealers were sent a TSB stating that the shaft should be greased on re-assembly in dealerships. So if they've had the transfer box off and found the shaft not to be greased they should have done so. |
Although (if my memory serves me) the TSB says that the coupling should be 'lubricated' using Weicon paste, which isn't technically a lubricant, it is an anti-seize paste. I have never really understood why this is specified.
When I last changed my clutch I used the most molybdenum-rich lubricant I could get hold of. My clutch will soon need doing again (it's down 60k miles since the last one, which is more than I expect a Puma clutch to last, and has become pretty horribly to drive), and it will be interesting to see what the output shaft splines look like now. AS I write this my 2007 DC has done over 210,000 miles on the original splined coupling. Now I have said this, it may fail on the way home, of course! |
| Paulv8 Member Since: 09 Jun 2013 Location: Milton Keynes Posts: 618
Silly question probably, but why is there this splined connection? Why isn't is a solid link?... After all, all the other boxes just have a male shaft straight in to the lt230. V8 90...WIP
| All times are GMT |
