![]() | Home > Maintenance & Modifications > INTERIOR window trim |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1125 ![]() ![]() ![]() |
will the interior side window trim from a tdci fit into a 300 tdi ? ,no window fitted as yet .
yes ,for the rear , I thought it would but was not sure .
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
I pulled the trims out of my 110 USW for some work last year, there's nothing different behind them that i could see, just looks the same as any other Defender. They hook on to the cant rail at the top and have about 3 fir tree clips along the bottom. Then the upper seat belt bolt goes through it. I think the only difference with TD5 ones is the small recessed bit halfway along for the forward facing seat brackets and there is a moulding at the back for the seat belt to come through.
(I realise mine is a 110, but the 90 ones are similar.) |
