Home > Puma (Tdci) > vac pump ? |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 |
Yes mine has just been repaced at the dealer due to leaking oil If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
13th Mar 2011 9:58pm |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
where about was it leaking no worries around the seal or the actual unit leaking what bits did they replace
steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
13th Mar 2011 10:33pm |
G4sweep Member Since: 24 Sep 2010 Location: Paderborn Posts: 182 |
Like noworries I have only two week back had my vac pump replaced. It was leaking from one of the seals which in turn had the fan throwing oil up on left hand underside of bonnet. I have a 07 plate puma and believe the vac pumps had three seals, the newer pumps now only have two( a mod which is hopefully for the better !). Mine was out of warranty but the AA break down repair cover I have covered a new vac pump! Sweep
2.2 110 XS SW ---------------------------- Gone; 08 D3 XS BN55 WPV G4 4.4V8 D3. O7 G4 Mongolian Recce 110 USW |
14th Mar 2011 8:10am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
ask them to fit the latest pump with the double seal or it'll go again 2.4 90 XS
1968 1/32 scale Britains 109 Pick up. Last edited by Grockle on 14th Mar 2011 11:00am. Edited 1 time in total |
14th Mar 2011 9:08am |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 |
I got my 09 plate 110 at around 5k miles. It looks like the pump went at one point in the past, as there was some residual oil on some of the surrounding components, and little bit on the bonnet... however once I cleaned it off (about 20K miles ago), there was never any fresh oil.
14th Mar 2011 10:44am |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 |
This is the mess they can make (1000 km's from nearest dealer!)
Click image to enlarge Click image to enlarge Puma 110 - gone Series III 1973 - going strong |
14th Mar 2011 2:55pm |
Nice iv just ordered a new one just to make sure
Regards steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
14th Mar 2011 3:02pm |
Hi Steve sorry for the late reply, they changed the whole unit for the new 2 seal one, probably just me but my brakes are much better now If everything is under control you are not going fast enough.
14th Mar 2011 9:24pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5024 |
Just to say...the failure (whilst i would get it fixed asap) always looks worse Mike
14th Mar 2011 9:59pm |
