![]() | Home > Technical > Central Lock kit/alarm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2230 ![]() ![]() ![]() |
Hawk do a good central locking kit, I retrofitted it on my 02 90.
As for tying it into the alarm I don't know on other types but on the TD5 you can buy a lil relay off ebay (£15) to solder on to the 10AS alarm unit then activate central locking via a Nanocom. Or you can send your 10AS unit away for the relay to be soldered on for a bit more. If its an older model then I believe Hawk do an all inclusive unit with an alarm system. |
okami Member Since: 06 Apr 2017 Location: Hertfordshire Posts: 90 ![]() ![]() ![]() |
Just bought a Hawk 2-way setup on ebay. We'll see how it goes!
Plus 1 for the Hawk kit, over time it does succomb to the same problems as a genuine fitment in that the wires between the doors and pillars break through the constant flexing but with a bit of patience when fitting the solonoids and rods they will give years of service. One tip would be is to leave plenty of slack in the pillar so when you get any hassle with broken wires you can pull more out of the pillar and rejoin
I had the exact same problem! My "solution" was to wrap the cables in braided nylon sheath and run the wires tight across the door stay, so the cable moved with the door stay and couldnt get jammed with minimal flexing.
