![]() | Home > Td5 > Swapping transfer and gear box. |
Paulv8 Member Since: 09 Jun 2013 Location: Milton Keynes Posts: 618 ![]() ![]() |
I just use a transmission adapter on a trolley jack and take both gbox and tbox out from the bottom. V8 90...WIP
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 333 ![]() ![]() |
not a bad plan. I reckon I could fabricate a transmission cradle fairly easily to fit my jack. Thanks
To be honest, at 35 quid from eBay it wasn't worth making one V8 90...WIP
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1784 ![]() ![]() ![]() |
I used an engine crane and dropped the gearbox and tbox as one lump, suspending it through the access panels
I used a bit of 4x3 timber on the transmission adapter (which has a variable angle anyway) V8 90...WIP
ply wood for my
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17869 ![]() ![]() ![]() |
If you have money to burn 100-045 SUPPORT BRACKET - TRANSFER BOX at a mere £69.15.
well I made a cradle out of scrap steel then went over to the steel place to buy some sheet for the series 1 chassis and they dropped in a free length of tube which I turned down using my drill press and a file to fit the hole in the trolley jack. Worked really well. Clutch, fly wheel and crank oil seal changed. Turns out there was oil contamination from a very leaky rocker cover gasket which I shall change. Did the spigot bearing as well using the hydraulic method of extraction.
On to the LT230 rebuild - not great news. Rebuild kit from ashcrofts cost about 100 quid - new sump (bigger capacity) and bearing spacers cost 100 quid, new diff gears 40 quid, needed a new selector fork, high gear assembly and high gear selector assembly 100 quid, sealant etc about 20 quid then I noticed that the garage that removed the box a year ago had failed to disconnect the high low and the difflock switch and ripped the wires clean out of both - cost 80 quid. I also went for a sleeved case (ashcrofts provided the sleeve and a local machine shop fitted it - 70 quid) and the HD cross pin for the diff at 45 quid. So that is a total of £625, cost of a recon box £500 + 180 if I wanted it sleeved, larger sump and uprated. I suppose I have learnt a lot and can be 100% sure everything has been done by the book but it has made me think that Ashcrofts prices are actually really good on their recon products considering the guarantee provided. |
