Home > My Defender > 1993 Defender 110 CSW Rebuild
Page 2 of 3 <123>
Retroanaconda
Last Saturday saw a quick trip down to Cambridgeshire and back to pick up a new front axle and some new calipers.
This one is in much better condition, so I will strip it down and rebuild it with new seals etc. as necessary and then move on to the rear.
Post #630506 11th Jun 2017 9:01am
Retroanaconda
Not much progress further, but little steps will get me there eventually.
Got the axle stripped down so I could assess what needed replacing, seems I'll need new swivel balls/bearings/seals plus drive members and associated hub seals and gaskets but the rest will go again which is good news. All the axle end station parts have been cleaned up and painted where appropriate ready for reassembly onto the casing once the new bits arrive:
I had to replace one hub as it had a broken drive member bolt stuck in there which had been partially drilled out off centre, but luckily I have a big pile of spare hubs so one was duly cleaned up and the new disc swapped over.
I then spent the best part of 6-7 hours scraping and scrubbing with white spirit to clean the axle casing of all the Waxoyl and general muck. It is in good nick though and is now ready for rubbing down and repainting prior to rebuilding.
Post #633459 25th Jun 2017 3:42pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Great progress so far Thumbs Up the cleaning gets tedious but its definitely worth the work. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #633460 25th Jun 2017 3:47pm
Retroanaconda
Some more progress this weekend. Got front axle painted and fully rebuilt and the rear dragged out of hiding and cleaned up.
Post #636565 9th Jul 2017 6:05pm
L110CDL
Great progress there Retroanaconda Thumbs Up Clayton.
Keeper.
Post #636625 9th Jul 2017 9:41pm
Retroanaconda
Bit of a delay in updating this.
Both axles now rebuilt and rolling, positioned under the chassis ready to be mounted up once a big box of shiny stuff from Land Rover arrives. Got the fuel tank mounted in as well.
Post #646558 27th Aug 2017 12:34pm
Profyaffle
Looks great.. you'll be rolling it outside before you know it! :thumbs:
Will you be treating the inside of your chassis? reason I ask is that I have a Marsland Galv chassis and was thinking of applying some Dinitrol cavity wax to the inside.. 1993 200Tdi Defender 90
Post #646594 27th Aug 2017 4:20pm
Retroanaconda
Here's hoping, need to do timing belt on the 90 so will need the chassis mobile so I can use the workshop.
Might stick some cavity wax in if I can be bothered, we'll see.
Post #646597 27th Aug 2017 5:23pm
Retroanaconda
Chassis now mounted on the axles Cool
Post #647907 3rd Sep 2017 9:35am
Matt90
United Kingdom 1990 Defender 90 2.5 TD HT Bronze Green
Coming along nicely, wish I had the room to attempt something like this👍
Good luck with the rest
p.s. Just double check where those doors were from you never know?
https://www.google.co.uk/amp/www.bbc.co.uk...e-37220084
Post #647927 3rd Sep 2017 10:56am
Retroanaconda
Thanks. The doors have been in my workshop for 6 years or so. They also came from a proper commercial scrapyard, not a pikey outfit, so I'm pretty confident that they're above board.
Post #647942 3rd Sep 2017 12:07pm
mk1collector
Excellent work Thumbs Up keep loads more pics coming please Ray
My build thread
Post #647945 3rd Sep 2017 12:32pm
L110CDL
Work of art, great progress Thumbs Up Clayton.
Keeper.
Post #648090 3rd Sep 2017 10:36pm
Procta
great progress there! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #648096 3rd Sep 2017 11:06pm
Retroanaconda
Put the engine in the chassis this weekend, fits nicely so far Very Happy
Post #649330 10th Sep 2017 2:19pm
Page 2 of 3 <123>
