Home > Puma (Tdci) > How many ...
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
How many ...
...HP does the Defender has? is it 122 or 140 ?
I've been having a discussion on Portuguese forum about the Puma engine ...
I have a friend that says that the 2010 model has allready 140 bhp from factory ... Is it true ? I was told that it had 122 like the Td5 used to ...
Any thoughts ? Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #63619 13th Mar 2011 11:08pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
just read this on the main LR web site:
"Defender’s refined 2.4 litre diesel produces 122hp or 90kW and a class-leading 360Nm of torque with 90 percent of peak power on tap from less than 2,200rpm to over 4,350rpm." BM52
Post #63620 13th Mar 2011 11:14pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
The latest version of the workshop manual also states that it is 140PS. So, maybe they changed it recently.
Pete
Post #63797 15th Mar 2011 1:46pm
18stone
England 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Yep, 140ps or 138bhp. It was discussed to a conclusion in a thread on here fairly recently. D300 HSE 110
Post #63800 15th Mar 2011 1:56pm
dgardel
Italy
Still, always and forever 122hp (90kW)!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #63803 15th Mar 2011 2:43pm
lrmaniac
XS Pete wrote:
The latest version of the workshop manual also states that it is 140PS. So, maybe they changed it recently.Pete
can you find a print, or print it, and post it here ?
did not find it ... can you point me to the thread ? I need to find arguments to maintain, or not, my discussion on the portuguese forum Very Happy
My thoughts exactly ... I've searched a lot and could not find anything written that says otherwise ...
... not forever if you get a remap ! Mr. Green Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #63806 15th Mar 2011 3:27pm
AndrewS
Not enough 130's have feeling's as well you know Smile
Post #63807 15th Mar 2011 3:54pm
XS Pete
If you have a look in the .PDF manual which Daniele sent out links to recently it's all over it.
For example:
page 6 in the index: 303-01: Engine - 2.4L Duratorq-TDCi HPCR (103kW/140PS) - Puma
page 292: Engine - 2.4L Duratorq-TDCi HPCR (103kW/140PS) - Puma - Engine
Description and Operation
I spotted 21 references to it in the index alone.
Pete
Post #63810 15th Mar 2011 5:05pm
lrmaniac
good idea ...
did take a look, and you're right,
but on page 295 it's also written this
it's not important, but I'm just curious... Is it diferent the engine power and power output ? Are both informations correct ? Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #63816 15th Mar 2011 6:19pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
From TOPIX website for my 2010 Defender 90:
Engine:2.4L DOHC HPCR DSL 140PS PUMA
Are we getting confused between the Engine output measured at the flywheel, and the Vehicle output measured at the wheels or similar.
NB: I'm not an engineer and haven't the foggiest if this is correct or not.
Post #63822 15th Mar 2011 6:38pm
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
IMHO, the engine itself, being used by Ford as a 140PS power plant is capable and known as a 2.4L - 140 PS unit, however Land-Rover has modified the ECU maps such that it only produces (a typical) 122 PS in our Puma Defenders. Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #63831 15th Mar 2011 7:09pm
bm52
I assume BAS or Alive who know these engines ECU maps would know the answer! BM52
Post #63845 15th Mar 2011 8:22pm
TJ101
All my last 4 drove the same, ( 07MY to 11MY ) bar the SVX, which i did not buy new, and recon it had been played with Whistle
But does it really matter ??? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #63879 16th Mar 2011 9:35am
MK
+ the use of lower tech injectors Puma 110" SW
Post #63896 16th Mar 2011 12:03pm
DefenderOfTheEarth
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Typical of LR to state two different outputs!
122bhp AFAIK - not 122PS. Defender 110XS SW gone... now VW California 180 4 Motion.
Post #63900 16th Mar 2011 12:48pm
