Home > Maintenance & Modifications > Merlin Smartbank
familymad
Merlin Smartbank
https://www.flatdoguk.com/merlin%2Dsmartba...tem%7E1383
Seems the guys that run the East Of England LR set up rate these. Anyone used one? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #636014 6th Jul 2017 8:16pm
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
I've got a smart gauge on my trailer. Two batteries, wired in parallel so treated as one.
Works reasonably well so that at a button push I can see remaining charge and decide if I need to haul out the solar panel or not. It is supposed to self calibrate over time, but I found that it drained the batteries when left connected over a period of time (trailer is stored off site with no power for maybe months without being used). SO I have to remove batteries and bring them home to be trickle charged. It is not connected long enough to properly self-calibrate.
So works reasonably well for me, but a voltmeter would probably have done as well for what I need. Interesting to see that they do a split charge, my current (ho ho) one is very simple and I worry that the second battery on the V8 is not being very well looked after.
Post #636082 6th Jul 2017 10:27pm
familymad
So not many using it and not a great review ...... hmm 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #636353 8th Jul 2017 7:58am
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
I have an M Power VSR and a voltmeter which I can switch to show each battery.
Works well enough for what I need and is a good chunk cheaper. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #636355 8th Jul 2017 8:12am
