Home > Technical > non starter after clutch change
Paulv8
1989 Defender 90 V8 Petrol CSW Alpine White
Dammit, just when I thought it was going so well......
Having spent ages, carefully removing the gearbox and changing the clutch, I finished putting it back together today.
The damn thing turns over but doesn't start.
I took great care to ensure we didn't dislodge any wires, or drag any looms when we pulled the box.... so I am reasonably sure no wiring damage took place. I also did check the crank sensor was reconnected properly.
Any ideas on what could have happened here? At a bit of a loss really. V8 90...WIP
Post #635420 3rd Jul 2017 9:53pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Did all the earths get tightened correctly? 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #635422 3rd Jul 2017 9:59pm
Paulv8
Yup. All were labelled and connected.
I really took a lot of time over the whole job... as its a second car I could plod along and make it enjoyable rather than a chore. V8 90...WIP
Post #635423 3rd Jul 2017 10:02pm
ickle
Immobiliser?
Lock it, leave it to set, unlock and try again?
GOOD LUCK
Post #635430 3rd Jul 2017 10:11pm
Paulv8
It turns over, so not the immobiliser. But I did try that too anyway. V8 90...WIP
Post #635438 3rd Jul 2017 10:26pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
Perhaps if you give some details of the engine and which injection system you are using ? A 1989 V8 would be on carbs and wouldn't have a crank sensor. http://www.yorkshireoffroadclub.net/
Post #635443 3rd Jul 2017 10:40pm
Paulv8
Lol.
It's my 2.2 puma usw 2013. I had sort of assumed that was self explanatory because as you say, the v8 doesn't have a crank sensor.
It really needs a plug in to get some live data but I don't have any trickery to do that with. I assume that somehow in unplugging stuff I have fractured a cable. I don't know if it's possible to check the crank sensor function without an oscilloscope or an engine diagnostic tool? V8 90...WIP
Post #635446 3rd Jul 2017 10:52pm
dorsetsmith
check crank sensor, cam sensor
http://www.defender2.net/forum/topic48321....p;start=15
Post #635477 4th Jul 2017 7:27am
Paulv8
So an update. My LR dealer says he doesn't know when he can get a new crank sensor "they are on back order with Land rover" he says.
I checked the wiring for continuity to the plug, the three wires to the crank sensor are all good. The plug is clean and located well.
Is the Engine light (the yellow engine picture on the dash) supposed to stay alight after the system self checks and only go out once the vehicle is started, or does it go out straight away once the self checks are done? V8 90...WIP
Post #635551 4th Jul 2017 3:36pm
Paulv8
Fixed. fractured accelerator cable shorting to earth V8 90...WIP
Post #635827 5th Jul 2017 9:10pm
Caterham
well done Thumbs Up
was it fractured through movement or did it get sqweeshed by the engine? Whistle
happy caravanning Thumbs Up
Post #635881 6th Jul 2017 6:56am
dorsetsmith
one to add to list good news Very Happy
Post #635886 6th Jul 2017 7:42am
Paulv8
Caterham wrote:
well done Thumbs Up
Clearly been previously fiddled with.. No outer protection and rubbing on the brake pedal box bolt. I assume I pulled it whilst fitting trim and clutch V8 90...WIP
Post #635917 6th Jul 2017 11:29am
