Home > Technical > Defender td5 headlights
Alextd5
United Kingdom 2006 Defender 90 Td5 XS CSW Bonatti Grey
My 06 td5 defender headlights are switched on and off via the ignition? The switch works fine. I don't think this is suppose to happen as I have never driven one with auto lights. Any help will be greatly appreciated
Post #635490 4th Jul 2017 9:01am
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
I think that's normal - my 2002 Td5 headlights switch off with the engine, just leaving the sidelights on.
Post #635501 4th Jul 2017 9:53am
dorsetsmith
ignition switch controls headlight relay and the headlight Thumbs Up
Post #635504 4th Jul 2017 10:01am
bankz5152
Its not auto headlights. It just cuts the power...
Post #635509 4th Jul 2017 10:27am
zsd-puma
It's designed that way, a lot of 80's Rover group products did the same. If you think about it, it stops you running your battery flat by leaving your headlights on overnight.
It will still leave your sidelights on, as these are essentially parking lights. (Side lights on without ignition is actually an MOT check)
Post #635524 4th Jul 2017 12:17pm
Alextd5
Hi thank you for all your replies. The problem I have is when I switch the ignition on the headlighst automatically come on even though the headlight switch is off. No side lights just main driving lights. I can then still
Turn the side lights on by turning the switch on. It's like the headlight have been powered by a switched live from the ignition. It's not the fact that they come because I left the headlight switch on. I hope you all undertand my bad explanation.
Post #635531 4th Jul 2017 1:08pm
miker
You said the switch worked fine! Sounds like the headlight switch has given up, but failed in the 'on' position rather than the 'off' position
Post #635532 4th Jul 2017 1:10pm
Mo Murphy
I'd be taking a look at the headlight switch, if the headlight switch is off the headlights should not be on regardless of the ignition switch position.
Assuming of course that you are in the UK and not somewhere where headlight legislation is different.
50 Shades of Pennine Grey
Post #635533 4th Jul 2017 1:18pm
rustandoil
Light switch is the main suspect here Smile
Post #635534 4th Jul 2017 1:23pm
zsd-puma
i expect the headlight switch has melted internally and the contacts are now permanently connected.
The switches aren't expensive. and you can just plug in the new one to test it before going to the effort of removing the steering wheel.
Post #635537 4th Jul 2017 1:26pm
Alextd5
Yes I have ordered a new switch OE Lucas. But the strange thing I forgot to mention is the tail lights are not constantly on but do come on with the sidelights once switched on
Post #635569 4th Jul 2017 5:52pm
dorsetsmith
edit you need 2002 wiring not 1999
Post #635572 4th Jul 2017 6:08pm
Alextd5
Thank you for the wiring diagram. I think this might be a weekend job. I was hoping it would be a switch.
Post #635579 4th Jul 2017 6:30pm
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
Normal - the tail lights are connected to the front sidelights, as said above the headlight contact on the switch has probably melted and fused together, this connects the headlights independently from the sidelights.
Post #635581 4th Jul 2017 6:39pm
dorsetsmith
My 2002 onwards sidelight and headlight wiring
Post #635591 4th Jul 2017 7:29pm
