Home > Technical > D2 key fob for a Td5??
VVS210
Have done a search but have not found the answer so asking the question in the hope that someone has done this.
I have just replaced the ignition & door locks with a new genuine set & now have the bigger bulky keys as well as the separate remote fob. I'd like to reduce the clutter on my key ring by swapping to a D2 key with the integral fob.
Has anyone done this & if so is it simply a case of getting the blank cut & then getting the fob paired to the car?
Thanks.
Post #635255 3rd Jul 2017 10:22am
bankz5152
I'm not 100% if the D2 fobs will work with the Defender but you can get a Range Rover style switchblade key for around £10, you just swap over the guts from your current fob and get the key cut. However the issue will be finding a key cutter that will cut your own key. In my experience they are not fond of cutting keys which are not supplied by them.
Post #635262 3rd Jul 2017 10:59am
Martin
Site Admin
The D2 key system isn't compatible with the Defender. The D2 uses a Valeo system, Defender is Lucas.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #635265 3rd Jul 2017 11:05am
VVS210
Thanks Martin, that answers that then Big Cry
Don't want to go down the flip key route as it's going to be just as bulky as having a fob & a key but I guess it's that or one of those custom D2 lookalike keys.
Cheers.
Post #635516 4th Jul 2017 11:01am
