![]() | Home > Off Topic > Taking cappings off and rivet guns? on a series, few things. |
Baz8046 Member Since: 08 Feb 2016 Location: Chatham Posts: 83 ![]() ![]() ![]() |
Hi, did mine on my Td5 at home.
It's a straightforward job just drill out the old rivets and rivet the new capping on. I just used a standard rivet gun the same as yours. You can support the roof and and get enough room to take the side panel out. When you fix the new rivets it's worth putting some tape around the rivets to stop the rivet gun scratching the paint. ![]() Click image to enlarge ![]() Click image to enlarge Defender Td5 Commercial 2002 Range Rover L322 TDV8 Westminster 2012 Discovery 4 SDV6 Landmark 2016 |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3854 ![]() ![]() |
^ Thanks is that a seal under the cappings?
Yes it has a self adhesive seal between the body and the capping.
I used some replacement double sided foam where mine was damaged. Defender Td5 Commercial 2002 Range Rover L322 TDV8 Westminster 2012 Discovery 4 SDV6 Landmark 2016 |
