Home > My Defender > RobbOnTheRock - 110 XS SW, 2.4ltr Puma
Page 3 of 3 <123
justinp
Assuming the 110 SW front section is the same as the 110 DCPU, then yes you can remove the front section with out taking it all down.
In the DCPU I had to remove the small side sections first before tackling the front panel. As a word of warning, the fir trees are a right PITA, so make sure you get a proper trim removal tool. Now gone - 2012 2.2 110 DC XS
Post #614296 3rd Apr 2017 7:37pm
mk1collector
Take the sun visors and mirror out then take all the fir tree clips out. Then it's just a case of gently bending the sides of the head lining out from the side plastic trims and it should come out of the back door. Ray
My build thread
Post #614321 3rd Apr 2017 8:34pm
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
Thanks chaps, will maybe have a crack at this at the weekend, but only if I can source the correct gland type connection.
However, I may have some help on that front.
More info when i progress a bit more.
Andy
Post #614528 4th Apr 2017 7:44pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Andy
Good to see the old girl is still going strong. Thumbs Up
Boy
[URL=][/URL]
[URL=][/URL]
Post #614655 5th Apr 2017 11:52am
ROBBONTHEROCK
Yep, thats the one.......yes i know the history, before anybody else says it.
So far so good, all i will say on that, don't want to jinx it!
Thanks Justin for the photos, much appreciated Smile
Anyway, I fitted the spotlights, ref the spotlight thread below:-
http://www.defender2.net/forum/topic53654.html
Not wired up yet, I'm having a real dilemma on what to do on that front to be honest, run cables up along the snorkel and cut out the old wiring job altogether, running my own loom to the battery box.
Or do i remove the headlining and do same as per the original set-up and retain the old loom....
If I knew the size of the hole before i committed to taking the roof lining off I'd be more comfortable, as i could amass the parts prior to doing the work.
I hate the idea of starting and being unable to finish as I haven't got the right part!!!!
See pictures below of the truck with lights fitted.
Andy
Post #615220 7th Apr 2017 8:39pm
ROBBONTHEROCK
So, today i fitted the LED Headlights, see LED headlight thread here:-
http://www.defender2.net/forum/topic52115.html
I really like them, they need to be re-adjusted, but otherwise they look good, and are better than the old set they replaced. So whats not to like???
HALO ring not wired yet, need the DRL controller to be fitted, next wkd job.
I also fitted my Cubby box cushion i bought 3 months ago.
One challenge is the cubby is not correct size, so the cushion is a bit undersized.......I will take a photo to show you all, but think its a reasonably easy fix, will google cubby boxes on eBay methinks.
Also removed and repainted the chequer plate on the wings....looks good now, and screwed tight to the wing now, due to binning the shagged rivets and replacing with nylocks and washers (SS).
Also removed the old wiring loom to the roof rack, mainly as I have changed my mind on the wiring route due to good suggestions on my Spot Light thread.
The old grommet in the roof is not leaking, so why disturb it? I will use the old conduit though to run some wires to the rear of the truck for work light etc.
Thats all for tonight Smile
Andy
Post #615684 9th Apr 2017 10:52pm
ROBBONTHEROCK
Wow its been a busy few months, have done lots to the truck and some maintenance too:-
Wired Halo up;
Fitted Foxwing;
Fitted rear ladder;
Fitted drop hitch (Dixon Bate);
Fitted new clutch;
Fitted new output adapter shaft
Fitted new seals;
New g/box and t/box oils;
Fitted new cubby box switches, for, rack, led bar and rear work lights;
Old Clutch:-
PS Old clutch was fitted in 2008 and his marked as such, also output adapter shaft had no grease, it wasn't badly rusted but showing signs of it starting to rust (78k miles).
Andy
Post #634852 1st Jul 2017 8:32am
ROBBONTHEROCK
Having an annoying problem.
Engine sounds like its pinking at low rpm, in some situations, not always, but sometimes.
Sounds fine when cold, and revs freely.
When hot, at low rpm, circa 1500 to 2200 rpm, when under load it sounds like it pinks or knocks, but importantly, the engine doesn't hesitate and revs freely, it still pulls very well, regularly pulling hard in 4th and 5th and 6th. Just an annoying acoustic issue Smile its not audible to my wife, just me..
Spoke to Ian at IRB (on a saturday night and sunday morning), and he suggests EGr or VCV could be a problem.
Diagnosis is to remove the MAPT and see how it looks as indication of EGR health.
Photos are below.
EGR ordered from Ian.......
May not solve it, but its evidence that its not working properly anyway.
EGR was last replaced at 21k, now on 78k...
Cleaned up the sensor with brake cleaner and refitted.
Andy
Post #635036 2nd Jul 2017 9:28am
ROBBONTHEROCK
Decided to clean the MAF as well, just, well, because. No issues, no reason to suspect it other than, easier to do it and learn how to do it I guess Smile
Only way to learn is to have a crack!!!
Anyway, see photos below Wink
Spray cleaned with brake disc cleaner, refitted and test drive - made no difference lol Smile
Andy
Post #635063 2nd Jul 2017 11:52am
ROBBONTHEROCK
One step closer to the holiday Smile
Andy
Post #635177 2nd Jul 2017 9:31pm
ROBBONTHEROCK
So lots to say.
A few preventative maintenance and some upgrades.
New vcv cured rough idle
New egr, old one was 50k old and noisy;
New rear shock bushes
New tires, BFG AT KO2'S
New Brake pads and pins.
New front ujs (t/box uj)
New brake lines fitted
New hel brake hoses fitted (rude not to)
Full service
Fitted cargo barrier
Outfitted rear load area with camping rig photos to follow (eventually) Wink
Andy
Post #640421 28th Jul 2017 9:57pm
ROBBONTHEROCK
Kicked off on our Grand Tour of getting Alps yesterday.
Travelled from Aberdeenshire to York yesterday.
York to Canterbury today.
Canterbury to Dover tomorrow morning.
Andy
Post #640423 28th Jul 2017 10:02pm
Page 3 of 3 <123
