Home > Td5 > TD5 2001 90 Anti Roll bars missing!
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
I have just replaced my fuel pump and realized that I don't have a rear anti roll bar fitted. I took a look at the front and that's not there either!
Should they be on my 2001 TD5 90 from the factory? There are bolt holes/brackets for both the rear and front on my truck. Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #634709 30th Jun 2017 5:13pm
bankz5152
So? Neither my o2 90 nor my 04 XS 110 had them. Often removed to aid articulation amd cheaper to remove than replace.
Post #634720 30th Jun 2017 5:49pm
mk1collector
Not all defenders came with anti roll bars Thumbs Up Ray
My build thread
Post #634722 30th Jun 2017 6:01pm
MC84
I'm just thinking the ride may be better with them than without them. I don't do any off road work.
Is there anyway to find out if mine was fitted with them originally and would I notice a difference if I was to fit them? Mike
Ford 100e 1959
Post #634740 30th Jun 2017 7:34pm
mk1collector
I fitted them to my csw as it does 99.999% on road duties and the difference in cornering was great Thumbs Up no more flopping around. Ray
My build thread
Post #634761 30th Jun 2017 8:09pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Only xs td5 had arb's I fitted them to my 90 and it was amazing the difference it made couldn't be without them now standard take offs from a puma will do the job but buy new drop links as they probably won't come with them think I paid about 50 for the 4 drop links and about 30 for the brackets for the bushes to fit to chassis holes are already there Front and back
Defo recommend you will love the difference 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #634797 30th Jun 2017 10:18pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
You only got ARB's if you specced alloy wheels! But not on a 110 station wagon I believe.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #634816 30th Jun 2017 11:25pm
MC84
Thanks for the reply's Guys. If the handling is improved with these fitted then I shall add them to my list!!
Thanks again Thumbs Up Thumbs Up Mike
Ford 100e 1959
Post #635003 1st Jul 2017 11:13pm
agentmulder
Kuwait
If you're on road most of the time, then fit them yeah Thumbs Up Solved the bowel problem, working on the consonants...
Post #635016 2nd Jul 2017 3:55am
proloFort
France 2008 Defender 90 Puma 2.4 XS CSW Java Black
I think there are two size that you can fit to the vehicle.
If you are not to do any off road driving like you to write I would recommend the thicker size.
Post #635017 2nd Jul 2017 6:23am
rustandoil
No anti roll bars fitted on TD5 double cab as standard, fitted some to mine and vastly improves road manners Very Happy
Post #635025 2nd Jul 2017 7:57am
MC84
I see Paddocks sell an Anti-roll bar kit (for both back and front) but its a Britpart kit. Does anyone have any other suggestion or recommendations? Mike
Ford 100e 1959
Post #635181 2nd Jul 2017 9:35pm
lightning
I fitted the Britpart kit to my 110 TD5, it was OK but the rear ARB was not quite right it was touching the fuel tank shield at the corners, l had to bend the edges over a little to stop it.
Later l fitted a genuine rear ARB and it was fine.
l also fitted the Britpart kit to our 90 TD5 and there were no problems with that one.
Both kits have been on for a couple of years and seem fine, apart from the problem with the rear one on the 110.
Post #635725 5th Jul 2017 9:18am
