Home > Puma (Tdci) > uneven gap
John051
Belgium 2010 Defender 110 Puma 2.4 XS CSW Java Black
uneven gap
The rear door on my 110 has an uneven gap on one side only on the 45 degree line. Is this normal? Is it possible that this gap can get bigger over time?
Also,
Under the plastic radiator grill paint is coming of in small flakes, is this normal? 110 is about 9 months old.
Gr,
J
Post #63435 12th Mar 2011 6:58pm
bob neville
J
Post a picture up of the gap if you can - this will help us tell you if it is normal or not.
Mine has uneven gaps everywhere - I would say it is probably normal and I doubt it will get larger.
If the paint flaking off is the small grill under the main plastic grill then the paint there does flake off - mine did and my dealer resprayed it under warranty.
Bob
Post #63438 12th Mar 2011 7:07pm
szracer
England 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Re: uneven gap
I had the same thing on the rear door of my 110, which is 8 months old.
I loosened the bolts on the door frame (and lock striker plate), and moved the door around a little to even out the gap.
Just standard Defender build tolerances, I think - You know the joke about the Toyota and the cat, I presume? Smile
Also,
Gr,
J
2010 110 XS USW (the slow one)
1960 Alfa Romeo Giulietta SZ (the fast one)
2005 Ducati ST3
1954 Sunbeam S8
Post #63517 13th Mar 2011 12:26pm
ralton
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
i've got gaps and poorly aligned panels aplenty. i'd say that's "normal".
peeling paint isn't good - take it to get fixed... www.ralton.co.za
Post #63546 13th Mar 2011 4:31pm
Grockle
paint flaking off the the lower grill is common,they paint staight onto the ally mesh which without a base coat corrodes with the road salt and comes off.your warranty will cover it 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #63653 14th Mar 2011 10:37am
John051
Here's a picture of the gap. Can a gap like this get bigger over time?
Post #63951 16th Mar 2011 5:37pm
bob neville
John
Something does not look right there.
Looking at the picture you appear to have some sort of filler strip between the two panels. Just checked mine, a 2009 model, and there is nothing like that fitted. A wild guess but it looks like somebody was trying to hide something.
I would get a dealer to sort it out.
Bob
Post #64116 17th Mar 2011 7:46pm
AndrewS
bob neville wrote:
John
Bob
I will agree with you there. 130's have feeling's as well you know Smile
Post #64144 17th Mar 2011 9:53pm
110SEB
That is not normal John. Ours does not have that strip. The gap there is not right. Off to the dealers - any problems give LR HQ a ring.
Post #64147 17th Mar 2011 10:05pm
spudfan
Ireland
The extra bit that you see on the lower panel goes inside behind the upper panel. It is an overlap between the two panels. I have seen this before. If you run your fingers along the roof gutter above this you will feel a dip or a rise depending on which way you run your fingers. The part of the roof gutter over the back windows will be slightly higher than the gutter over the front doors. The reason for this is that the body over the top panel in your photo will be slightly higher (by the width of the gap in your photo) than it should be. The only way to rectify this is by major surgery. If you are happy with your Defender and this is the only fault you have I would leave it be. Getting someone to take the roof and panels off to make them fit then reassembling it correctly could cause bigger problems in the long run.I have seen this type of thing before. It will stay as it is so my advice is to live with it. I gaurantee you that if you check this join on any Defender the passenger and the driver sides will not be the same. You dealer will tell you that it has to go to the body shop and you are depending on them to strip, repair, reassemble, reseal and not muck up your interior while doing it. My two sides are not 100% the same but so long as everything else o.k is I am happy. Your choice but apart from the visual aspect of things it will be o.k. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #64175 18th Mar 2011 12:28am
BruceT
South Africa
That gap to the left at the point of the door, where the two body panels are fitted together, looks huge. Biggest I have seen. Mine is around 2mm thick or looking at the rivets about the size of the center hole in the rivet.
I would get it repaired as it looks like it could fill up with muck, water etc......
Post #64232 18th Mar 2011 1:12pm
Looks about the same as mine, within normal tolerances. I wouldn't worry about it.
Post #64240 18th Mar 2011 1:39pm
BruceT
South Africa
Just to reiterate....I am talking about the gap between the two panels to the right of the door not the door to panel gap. (i.e. where it looks like you can stick your finger into the square hole)
Post #64242 18th Mar 2011 1:41pm
Yup, so am I. I can stick a pencil down that hole on mine!
Post #64247 18th Mar 2011 2:10pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
I took a pic of mine (will upload when I'm not so hectic) but as said above, the flange normally fits behind the rear panel.
Mine is out by about the same amount. It's what they use to adjust the tolerances.
You could get it changed but it's a big job so you'd want to trust the people doing it and you could get back something which is wrong in a different way.
If it isn't leaking then I'd just leave it. Thumbs Up One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #64645 21st Mar 2011 11:08pm
