![]() | Home > Puma (Tdci) > Questions on left foot breaking for traction control |
Surely the whole point about anti-stall is that it won't stall anyway? There's a well known video of a Puma 90 pulling an artic on gravel at tickover that demonstrates it.
Left foot braking can overcome a spinning wheel to maintain momentum in a non-electrikery equipped vehicle, but will more likely hinder the whole process in a later one. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
stuart123 Member Since: 03 Apr 2017 Location: Manchester Posts: 207 ![]() ![]() ![]() |
Yes, i've seen that video - but nobody is pressing the brake pedal.
If there is a no traction control why would left foot braking hinder the process? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17873 ![]() ![]() ![]() |
The TDCi engine management system knows when the brake pedal is pressed and will behave differently under different condtions.
You can however brake *gently* under any conditions without problems. it is of course essential that you can stall the engine with the brakes since this may be necessary under emergency conditions, and I suspect that it is a requirement for type approval. Crawling on soft sand is a good way to get well and truly bogged. Actually, just being on soft sand is a pretty good way to get bogged! How soft is soft? |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
As far as possible, tow in low range to overcome an obstacle.
I have applied left-foot braking when driving offroad many times, especially in slow & tricky situations where you don't want high rpms and/or wait for the traction control to kick in. By applying a very light braking, you're just making sure that you have traction at very low speeds/rpm. But I'm sure you won't need to with the Puma, as long as you deflate tyres down to 1 bar (or even to 0. ![]() ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2540 ![]() ![]() ![]() |
I was extremely concerned when I read that you were contemplating crossing soft sand whilst crawling. Soft sand is the most difficult terrain to master and can be a beginners nightmare. Soft sand will sap your power and you must at all costs keep the momentum going, left foot braking will reduce the power and consequently your momentum. You also have the added problem of towing a boat and up a slight gradient. You have to ask yourself the question - will the trailer tyres float on the surface of the sand or will they dig themselves in, again this is another reason to keep momentum.
I certainly wouldn't want to be applying the brakes on an incline. A golden rule for soft sand is not to stop and if you do, make sure you are facing downhill. You are also going to have to consider deflating the tyres to improve flotation, down to 1 bar has been suggested above - you can go lower but then you run the risk of the tyre breaking the bead. Also be aware that steering becomes more difficult with ultra low pressures. I think if I were you, having been stuck once and knowing that you do not have enough space to build up momentum then I'd be looking for another solution. Defender 90XS SW Mini Countryman Cooper S Morgan Plus 8 |
Thanks for that, all very helpful. Perhaps might be slightly more than crawling but there's limited area for any extra speed or run up sometime... The defender stays away from the water but there's a gap between the area of hard sand and tarmac that is inevitably soft and little space for a run up etc. |
Thanks for that. It's not an impossible situation when I go get stuck as there's people around and it's not remote... just recently heard off left foot breaking and wonder whether its something I should be trying in that situation... might be more than crawling but still only going fairly slowly.... Trailer tyres definitely dig in! |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
has your defender got traction control?
if so i would have thought low range diff lock and a bit of throttle and it would sort itself out (lower tyre pressure if required) DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 926 ![]() ![]() ![]() |
As already mentioned the key to sand is LOW tyre pressure and a momentum preservation, Anti stall will aid in getting going as the drag in softer sand is quite considerable and towing won't help Whilst not knowing the exact situation and the size of your setup then use of 2nd low with the anti stall to get you moving then building on that to increase speed enough to still have control yet not risk the drag pulling you to a halt.
If you have space then consider using the technique of before traversing a bad patch to go forward and backwards gently a few times in the same spot a vehicle length or three to compress the sand and give you a firmer runway to help in that initial 'launch' as you can accelerate harder then just on virgin sand. |
I forgot to add that I only use left-foot braking on rocky obstacles, where precise control and low speeds are required
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 ![]() ![]() |
What he said + if you feel you have to use low ratio then use 2nd as 1st is just likely to spin the wheels up & dig you in - personally I would use as high a gear as I thought I could get away with & slip the clutch a bit to get things moving. Your boat & trailer will be acting like a huge anchor dragging behind you. Good luck & make sure you post pictures when you're bellied out on the beach... ![]() |
Thanks for all the comments! I'm probably making the situation sound really bad - it's not... just wanted to make life a little easier if possible.
LR90XS2011 - I don't have traction control (other than my left foot!!) Devon-Rover - prefer to leave the tyres pressures normal as it's only a small stretch on soft sand and then the rest is road. Appreciate if I get in a pickle though it's an option! Does anti-stall work in all of the low range box then? |
Anti-stall works in all gears (12 F, 2 R) but only when there is no throttle input.
