Home > V8 > v8 slow return to idle |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10360 |
Is this from cold or when up to temperature?
26th Jun 2017 9:55pm |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
Have you lubricated the linkages and cable lately? 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
26th Jun 2017 9:57pm |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Dash pot oil level ok? 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered. |
26th Jun 2017 10:02pm |
Nige71 Member Since: 05 Jun 2017 Location: bristol Posts: 38 |
seems same hot or cold
haven't checked cable lubed up dash pot oil ok Thanks for info |
27th Jun 2017 6:54am |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1746 |
Adding to Mash...are the pivots/linkages clean and not gunked up?
Also return springs weak? Disconnect throttle cable from engine and see if issue occurs then you know if it an issue at the carb or throttle pedaland cable. |
27th Jun 2017 6:14pm |
thanks will try linkage .
27th Jun 2017 9:13pm |
Have checked the return spring and is very strong on the return , the cable is very loose and lubed ?
2nd Jul 2017 8:52am |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 |
if you have SU carbs it might be the poppet valves on the butterfly are sticking. Options include, replacing the butterflies like for like, soldering the valves shut, or throwing the butterflies in a bin and fitting plain butterflies. That way you need never worry about the problem again and you get rid of a restriction in the airflow
25th Aug 2017 4:30pm |
