![]() | Home > Puma (Tdci) > Suspect battery? |
| Farmer58za Member Since: 20 Jan 2017 Location: Worcestershire Posts: 85
Looks like my (2012) battery is on the blink. Everything works but it struggles to turn the motor and then the battery alarm sounds...
What's the correct Ah rating for the battery? I have an original LR (CX23-10655-BA) 90Ah battery installed. All the online places call up a 70 Ah battery (??). Finally, is there a preferred brand, that won't put too much strain on my wallet? Thanks David Dave's not here man... |
| IanW Member Since: 12 Jun 2011 Location: Gloucestershire Posts: 172
I bought a 100amp one from a firm called Tayna a few weeks ago. Free next day delivery and v helpful on the phone - 01745 823399. I replaced the original 2008 one on the 110 with the higher capacity one. Very slightly bigger but fits in the under seat compartment nicely. At the risk of teaching you to suck eggs a look at the handbook on battery disconnection is worthwhile. One wife - livid
I ended up buying a 100Ah/900A unit, with 5 yr guarantee, from a local battery dealer for good price.
Followed the manual to the letter and there were no nasty surprises. Thanks all. Dave's not here man... |
| bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027
Ctek charger in recondition mode
2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
| keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2279
David Replaced my 2012 today . Ģ125 No issues and starts well . Click image to enlarge |
Snap!
Got one of those too |
It's only a battery , they don't last forever you know
Although my original one is still ok-ish its beginning to slow crank and set the immobiliser alarm off if sat for a few days without running . It's approach 5yrs so can't grumble . The replacement shown is exact dimensions and shape as original except at a significantly lower cost and seems to be of excellent quality . Keith |
| zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720
Duplicate post
It's also a higher capacity. I've got that Yuasa too. Notice on the base there are some removable plastic bits, if you lever them off with a screw driver, they fit better in the Defender's battery tray. |
| Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060
I second that. Ctek charger work wonders with tired batteries. 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
| All times are GMT |
