Home > In Car Electronics > Soldering iron.
Page 2 of 3 <123>
Fatbaron
I bought myself a cheap Draper. I thought it was crap at first but turns out my skill level was the problem. Bit of practice makes perfect!
Post #627890 31st May 2017 7:43am
L110CDL
Thanks all for your reply's, very interesting Very Happy Clayton.
Keeper.
Post #628097 31st May 2017 11:05pm
Martyn668
What about the Watts? Very Happy I have a 25W soldering iron, but I found that while it would melt the solder, I had real difficulty imparting any heat into a copper wire so that the solder would stick to it (heat conduction?) A higher powered 40W iron has helped somewhat but I've been flicking through the Machinemart catalogue today wondering if I shouldn't go 100W+. Or gas. Could all be lack of skill of course, but like I said, the jump from 25W to 40W did help.
Post #633298 24th Jun 2017 5:29pm
JWL
It does help if you've got an inverter fitted in your Defender, best of both worlds then Thumbs Up
Post #633369 24th Jun 2017 10:48pm
If you need a 100w (or even 40w for that matter) iron to solder wiring then you're definitely doing it wrong. Using flux solder makes for better results, in my experience. Darren
Post #633371 24th Jun 2017 10:59pm
agentmulder
Kuwait
Basic Hakko station at home.
Pace SMD/rework station at old work, super fast to get up to heat and change tools that one. Thumbs Up Solved the bowel problem, working on the consonants...
Post #633387 25th Jun 2017 5:07am
agentmulder
Kuwait
Spend time imparting heat to the larger sink beforehand (often the ground plane). Then keep at it retaining the heat on the same problematic net if you can. Solved the bowel problem, working on the consonants...
Post #633388 25th Jun 2017 5:12am
Martyn668
So if 25W should enough, and I've spent time "pre-heating" the heat sink (the long copper wire), to accept the flux-cored solder, I think I'm doing it right. (Although I expect OK, rather than perfect might describe my technique, "room for improvement" as the saying goes.) How much difference does a worn tip make? Both of the tips are pretty pitted tbh, but I figured it's not about aesthetics. Even a lumpy tip should still heat up right? When and why do you need to change tips? Might have a quick poke around YouTube to see if there are any soldering lessons. By the way what's a 100W soldering iron for then? Just really big wires? How big? Battery/winch leads (along with the crimp, which is the main contact.)
Post #633429 25th Jun 2017 11:58am
Martyn668
So looking on YouTube, I definitely need to keep my tips cleaner. Seems like a lot of oxides collect there and prevent good flow. Also some additional rosin flux to smear on beforehand.
Post #633443 25th Jun 2017 1:31pm
Yeah, keeping the tip clean is essential. Ideally, you should aim for the tip to be tinned with solder before you start, but that only works if the tip is smooth and clean.
My wife uses a 100w iron for assembling stained glass, but they're also useful for soldering much larger cable where the extra power offsets the heat sink nature of larger material. Darren
Post #633558 25th Jun 2017 10:14pm
Martyn668
There seems to be quite a bit of "material" in the tip. If it is pitted/dirty, can I sand/grind this away? What's underneath is shiny copper colour. Or am I in danger of creating a short, or damaging it in some way? Can I keep grinding until the tip is too short to be useful before replacing it, or do I replace it when it starts to pit/before that?
Post #633570 25th Jun 2017 10:42pm
You won't short anything out but if you've removed the original coating to expose the copper core then I'd fit a new tip. Darren
Post #633578 25th Jun 2017 10:57pm
Martyn668
OK, thanks. Are tips all universal fit, or should I look for ones specific to that manufacturer /model?
Post #633584 25th Jun 2017 11:12pm
No, they're model specific. Darren
Post #633614 26th Jun 2017 7:47am
Martyn668
Hmmm, I suspect it's cheaper to buy a new soldering iron than a spare tip, just like printer cartridges or replacement chucks for a drill (different thread). Anyway off to the shops I go. Thanks to everyone for all their input. BTW, watching the YouTube teaching videos, was struck by the American pronunciation of soldering. Almost makes it sound like a different word. Sort of "soddering" with a long "o". Weird.
Post #633622 26th Jun 2017 8:52am
Page 2 of 3 <123>
