![]() | Home > Maintenance & Modifications > replacing crewcab/SW second row crossmember (td5) |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218
I have heard of people making/cutting the crossmember in half, then re-attaching both halves (be it welding in situe, or having pre-welded on tabs and bolting it together) once it's back under the rear bodywork.
| Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1751 |
Use this one from YRM
https://yrmit.co.uk/product/110-mid-crossm...-defender/ |
| MalteseRover Member Since: 02 Jul 2013 Location: Gozo Posts: 137
i am going to fabricate one myself. sadly postage costs put me off. i have a "friend" who builds truck beds and is great at sheet metal press. we can do it easily using 3mm sheet and have it galved here. i am thinking of doing it a half inch shallower to help
installation but since i will remove the alu upright part... it can drop from above. |
| rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243
Did mine by removing the second row floor and sliding the new one in from there. Was quite easy, just need to watch the fuel lines.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
| All times are GMT |
