![]() | Home > Maintenance & Modifications > Extended warranty or selective parts upgrade for reliability |
| LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3680
clutch again and gearbox to transfer box adaptor shaft DEFENDER 90 TDCI XS,
| Pat Member Since: 05 Dec 2016 Location: Somewhere new! Posts: 371
My 2 years are also about to run out and have been sent bumf regarding extending.
Anyone got strong views about further extending warranty? Only needed an oxygen sensor replacing so far. Edit ... I forgot ............. was told at MOT time, that I had a slight leak on a swivel joint and to book it in before my 2Y warranty was up. A couple of months later when I got round to having it done, they surprised me by doing both! Last edited by Pat on 22nd Jun 2017 8:04pm. Edited 1 time in total |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4803
It's one of those things that if you don't take out and need you'll be kicking yourself for not going for it. By equal measure it is very expensive peace of mind! 2002 90 Td5 Station Wagon
| corgi1 Member Since: 26 Feb 2017 Location: bucks Posts: 440
I'm thinking about my extended warrantee, got it about 6 months ago with a years warrantee, how mush would it cost to renew, any ideas ?
cheers Pete |
| Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3667
I've just extended mine as the 2 year warranty is up.
Mine has only had a new swivel and rear door wiring harness in the two years I have owned it. I have taken the warranty out as peace of mind. The other option was to put the £69 or so a month into a savings account and try to dodge the bullet for 18 months or so hoping that nothing goes wrong so you have a bit of a slush fund for the unexpected. It seems expensive, but I work on the basis that I have already forked out a shed load of money buying the Defender, I realised before purchase it would be 'unique' in its maintenance requirements so I decided to take the hit. Now, I can see the sense in changing the bits that are likely to fail with a better quality alternatives. Tough call. I suppose it all comes down to what is affordable to the individual? |
| agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324
Going by my experience, I'd expect clutch and clutch hydraulics (slave and master).
Also various transmission elements building up to backlash issues. Check for unreasonable corrosion and leaks. Wipers behaving? Swivel seals. Solved the bowel problem, working on the consonants... |
Anyone know how strict LR are with Warranty if service plan hasn't been followed?
My 62 plate has only done an easy 17K and last July declined a "big" service and made do with a "small" service. |
| All times are GMT |
