Home > Tdi > 300Tdi Head Gasket
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
300Tdi Head Gasket
Good morning defender land,
I need a bit of advice.
I have a strange tshh noise coming from the engine. It doesn't appear to be the exhaust manifold gasket like last time although similar.
Having had a look around the engine block has a coating of oil below the head gasket line so I'm thinking it is new head gasket time.
Is the Haynes workshop manual ok to follow regarding changing the head gasket or should I be doing things differently?
Thanks in advance for any comments and help. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #632835 22nd Jun 2017 12:08pm
trickster5000
United Kingdom 1989 Defender 90 300 Tdi CSW Arles Blue
I did it as per the Haynes manual and was fine although for the most part you can sort of see what bits need to come off to get the head off. The Haynes helps with what order to do things in.
IIRC it says to remove the exhaust manifold and turbo at the downpipe, I found this wasn't necessary and could easily push it out of the way enough to get the head off.
Otherwise it should be a fairly straightforward job unless you get some particularly nasty bolts on the manifolds Rolling Eyes
Good luck Thumbs Up Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html
Post #632868 22nd Jun 2017 1:42pm
Bps
I'd check all turbo hoses and intercooler 1st before taking the head off
Post #632928 22nd Jun 2017 6:19pm
