![]() | Home > Maintenance & Modifications > Removing offside front wing. |
| zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720
Park the car around the other way so you can access it from the West. |
| Bushpig Member Since: 07 Nov 2013 Location: Risca, Wales Posts: 236
I've not removed one from a modern LR, but the WSM has it all in there... Good Luck Douglas Adams 2012 2.2 Puma |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
unbolt wing section i.e outer from top.
| Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696
I took that side off quite recently and it's pretty straight forward, unlike the near side. Mine doesn't have ABS though, so that may add more of a challenge.
| Lightningtweeds Member Since: 16 May 2017 Location: Fintry Posts: 461
Many thanks! 👍
| All times are GMT |
