Home > In Car Electronics > Remote Switch
discomog
Remote Switch
I have a 3 metre boom sprayer which I tow behind my Defender for spraying my grass paddocks. The sprayer utilises a 12 volt dc electric pump to pressurise the system. The sprayer is wired to the Defender via the 13 pin tow socket. The disadvantage with this wiring is that I have to get out of the cab to switch the pump on and off. Does anyone have any experience of using a remote switch that I can control from inside the cab. If so I would appreciate your recommendations.
The pump motor is rated 7 amps at 12volts dc Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #632214 19th Jun 2017 12:23pm
There are lots of ways you could do this, depending on how complicated you're prepared for it to be. All involve adding something to the sprayer rather than the Defender, to keep it neat and self contained.
One option would be a wireless remote relay (Hella do one that's rated for the load, although I expect there are others), with the relay itself fitted into a waterproof box.
Another would be a regular relay, similarly mounted, with the trigger connection to the side light circuit of the towing connection. That way, you turn on the sidelights to power up the pump.
A third, slightly more involved solution would be a changeover relay with the trigger connected to the reverse light circuit of the tow bar. Briefly select reverse to turn on the pump, select it again to turn it off. Darren
Post #632219 19th Jun 2017 12:38pm
Presumably the sprayer is using the ignition-controlled 12V supply usually used for caravan fridges etc in the 13=pin socket?
If so, why not just wire a manual switch into the supply (or into the circuit actuating the ignition controlled relay which controls the supply)?
Post #632230 19th Jun 2017 1:39pm
discomog
Hi Blackwolf. The sprayer pump is connected to a 13pin plug with only two wires, pos and neg that connects into the 13 pin socket on the Defender. I would prefer not to modify the defender wiring if I can get away with it and therefore like the idea suggested by LR Anorak of a wireless remote switch.
Thank you both for your suggestions, I'll do a Google search for a Hella remote switch. Defender 90XS SW
Morgan Plus 8
Post #632251 19th Jun 2017 2:46pm
Martin
Site Admin
Does the sprayer run as soon as it is plugged into the Defender's socket, or only when the Defender's ignition is switched on?
If the latter you can interrupt the ignition feed as it done by a relay generally fitted in the seat box and the feed taken from the upper dash switches.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #632265 19th Jun 2017 3:05pm
discomog
Hi Martin,
It is wired into the 12v ign circuit (pins 10 and 11). i need to be able to switch off the pump remotely whilst the engine is still running. Defender 90XS SW
Morgan Plus 8
Post #632270 19th Jun 2017 3:09pm
Martin
Site Admin
Brilliant Mr. Green
You can modify the ignition supply to pin 10 to add a switch inline.
In your left hand (battery) seat box you should have a relay like this:
(if it is missing the fuse on the side it is likely an aftermarket kit so a different approach would be needed).
Simply remove the fuse and fit a switch on fly-leads and spades on the end, including a fuse sufficient for your pump (i.e. 10A) in the fly-leads.
This would interrupt the supply to the relay and hence the supply to anything downstream.
This gives you a non-intrusive and totally reversible mod to switch your pump off from the cab.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #632276 19th Jun 2017 3:22pm
Martin
Site Admin
Edited above slightly for fuse  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #632277 19th Jun 2017 3:27pm
Martin
Site Admin
2015 D90 XS SW
Post #632279 19th Jun 2017 3:43pm
^^ Exactly what I had in mind, only much, much better explained! Thumbs Up
Post #632283 19th Jun 2017 3:58pm
Martin
Site Admin
Just stumbled on my diagram for this and wondering whether you did this and got it working?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #665074 17th Nov 2017 1:40pm
discomog
Thanks Martin. This is on my list of "Jobs to do this winter" as I will not be using my sprayer until next spring. I'll let you know if it works but I'm sure it will. Thumbs Up Defender 90XS SW
Morgan Plus 8
Post #665076 17th Nov 2017 1:47pm
Martin
Site Admin
Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #665082 17th Nov 2017 2:05pm
