Home > Technical > Ticking noise 300 TDi
Roosterrs
My. Defender is a P plate 300TDi 90 CSW. 120,000 miles.
It has recently started to make a ticking noise when accelerating and today it has been more noticeable.
It seems to be when it comes onto boost. I can lift the throttle and it stops and then reapply and it will start again.
So I think the temperature makes it worse as some days it doesn't make the noise or is a lot less noticeable.
Trawling the net, it could be head gasket, valve top retainers, exhaust gasket, but I would of thought it would make the noise all the time if it was.
The vehicle seems to run OK otherwise.
As it seems to be temp and boost related, could it be diesel knock?
Any info gratefully received.
Post #631831 16th Jun 2017 3:47pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
Without hearing it I wouldn't know, but a few years ago and at a similar mileage I had a similar audible phenomenon on my 300Tdi. I looked at all sorts of things before giving up and taking it to an Indy. We were going to take it for a drive but as soon as I started to pull out of the parking space the chap said "no need that's the exhaust manifold gasket". It was he was right it had fractured around the hole on the nearest cylinder to the bulkhead. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #631833 16th Jun 2017 4:00pm
Again, difficult to be sure of a described sound, but I remember something similar on my old 300tdi Discovery being the vacuum pump on its' way out. Darren
Post #631834 16th Jun 2017 4:08pm
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
I am sure this is not the noise but could it be the speedo cable ticking inside the speedo head??? Whistle If so some oil or a grease at the head end would quieten it Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #631841 16th Jun 2017 4:40pm
trickster5000
United Kingdom 1989 Defender 90 300 Tdi CSW Arles Blue
Mine was making a fairly loud ticking noise that gradually got worse. The head gasket had gone and was blowing out at the back near the bulkhead.
Obviously there's a whole range of possible ticking noises, this one was fairly loud, easily audible above idle engine noise and the ticking frequency increased with engine revs.
Hope this helps Thumbs Up Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html
Post #631842 16th Jun 2017 4:47pm
Roosterrs
Thanks for all the replies.
Vacuum pump replaced with a genuine Wabco pump about 1 year ago.
Doesn't make the noise at tickover, just when it comes onto boost.
Can you upload a video onto this page?
Post #631872 16th Jun 2017 8:32pm
trickster5000
Not directly. The easiest way is to post the video on YouTube and put the link on here. Matt.
Post #631874 16th Jun 2017 8:45pm
sako243
Does it follow engine revs, road speed, and so on? Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #631894 16th Jun 2017 10:51pm
Roosterrs
Yes, increases with engine speed.
Put my hand behind head and can't feel any blowing.
Post #631935 17th Jun 2017 3:13pm
yostumpy
you can spray the area when it running, not sure if it soapy water, or wd 40, Big Cry but something like that, and it blows bubbles, if its leaking
Post #631976 17th Jun 2017 7:51pm
Roosterrs
Definately head gasket. Took head off tonight and its blowing out the rear.
I was told the head would need a skim but the LandRover book says not to.
I havn't checked the flatness yet but anyone know if you can skim the head?
Post #632531 20th Jun 2017 9:54pm
trickster5000
I had mine skimmed when it was doing the same thing.
It really depends if it has been skimmed before. You can tell by looking at the gasket. It will have a certain thickness indicated by the holes on the outside I believe but I can't quite remember which holes indicate what thickness of gasket (hopefully someone more knowledgeable will come along to explain). If you do get it skimmed, you will need to fit a slightly thicker gasket when you put it back on to compensate for the material removed.
Hope this helps Thumbs Up. Matt.
Post #632536 20th Jun 2017 10:03pm
Roosterrs
It has a 3 hole gasket fitted which is the thickest I believe.
Havn't measured piston protrusion yet.
Post #632548 20th Jun 2017 10:34pm
Roosterrs
Checked head flatness with a parallel. Very very flat. Cannot measure any defect where its blowing. Cannot measure a 0.001" gap with a clock or feeler. I think it may just be a min to clean to remove any imperfections.
Post #632722 21st Jun 2017 9:14pm
trickster5000
Have you checked to see if it's marked the block where it was blowing? If it hasn't marked the head then the block should be fine but worth a check. Matt.
Post #632743 21st Jun 2017 10:17pm
