Home > In Car Electronics > 12V feed for 85W fridge
Emile
Netherlands 2013 Defender 110 Puma 2.2 SW Fuji White
What is the best way to feed a 85W fridge in the back of my 2013 110? I did connect it with the sigaret lighter but together with my iPad and iPhone charging, all got too hot and resulted in several melted plugs. The iPad needs continue charging as it is used for navigation. Off course the fridge also is connected continue and for many hours. Is there a 12v feed in the back that can hold 85W for long periods? Thanks!
Post #626948 26th May 2017 9:24am
Sticky
England 2016 Defender 130 Puma 2.4 HCPU Stornoway Grey
I'm afraid a dedicated and fuse protected supply is your best bet.
It's an opportunity to put in battery protection too.
My only other input is to ensure you put a decent gland on the battery box when feeding the conduit. I recently saw a wire cut through and welded to the metal when vibration had cut through the rubber grommet.
Post #626952 26th May 2017 9:34am
Emile
A direct feed from the battery has become my choice. Got some 2.5Qmm wire and a Kemo M148A Battery Guard. The only thing I have to attack now is the connection with the fridge as I take it out and put it back in every day on the trips we do. Avoiding sigaret lighter plugs there seem to be not so many options. Any advice on good quality 12V plugs? TIA
Post #631499 15th Jun 2017 9:37am
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
I've never seen a good quality cigarette lighter plug - horrible things. For that current I would probably use Neutrik Powercon or Speakon. These are highly reliable professional audio connectors with excellent strain relief.
Both are available from CPC
Post #631515 15th Jun 2017 10:16am
ericvv
Post #631518 15th Jun 2017 10:28am
Bushpig
Wales 2012 Defender 110 Puma 2.2 SW Alpine White
For my fridge, I use the Hella plug setup.
Does not work loose, avoiding a short curcuit in the plug and potentially frying the fridge.
Can also be made 'water resistant'...
 Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #631612 15th Jun 2017 4:26pm
miker
Anderson powerpole are pretty standard for 12V at a reasonable current.
Speakon are great, and I plan to use a couple for a similar purpose. They're not "rated" for DC though, and it is a non standard use of the outlet.
Post #631629 15th Jun 2017 5:19pm
