- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
It should shut off on its own after 5 or 10 seconds. IIRC it's triggered by the ignition powering up (position 2) but I think there's also a feed from the starter solenoid, so if you turn the ign to pos2 but don't actually start the engine (like if you want to wipe your windows as the wipers don't work on pos1 ) then when you crank the starter the glowplugs will heat up again...
so maybe you've got that one mixed up somewhere?
13th Jun 2017 9:15pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
