Home > Puma (Tdci) > Dog Guard -
GN
Dog Guard -
Puma 110 XS - how difficult is it to fit the genuine LR dog/cargo barrier?.
Also is the barrier/guard split? - can the bottom be removed leaving the top in place?
(to allow longer items to still be loaded without removing the whole thing?)
Post #62545 6th Mar 2011 9:08pm
Very easy to fit in a Land Rover way
Its a two piece unit but you'd have to fab your own brackets up
Post #62552 6th Mar 2011 9:58pm
JSG
The genuine one I fitted to my old 07 TDCi had a drop down flap in the lower section for long loads.
It was a real pig to fit though - none of the brackets lined up so I had to bend / adjust them all. John
2011 Tdci 110 CSW XS
Post #62555 6th Mar 2011 10:11pm
lyon99
Scotland 2010 Defender 110 Puma 2.4 USW Java Black
I fitted a genuine cargo barrier/dog guard took a couple of hours had to bend it a bit to fit, The bottom part is rigid well it is supposed to come off and has hinged part in the middle 600mm by 300mm,The top part comes off in ,a couple of minutes, I leave the bottom part in as that was a pain to get in line, Got mine last year for my 110 usw 2010,
Lyon 110 Utility puma 2.4 2010
110 pick up 300 tdi 1998
Fendt 716 Vario
Post #62558 6th Mar 2011 10:43pm
Happyoldgit
Fiddly and time consuming more than difficult. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #62756 8th Mar 2011 11:18am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
It's straightforward (technically) but requires a lot of fiddling. I re-shaped one or two of the brackets in a vice to make it fit better. It'll take a couple of hours.
I'd suggest you bin the very soft Allen-key bolts that come with it and buy proper hex-head stainless bolts. They're a standard thread (m8 IIRC) but it'll save you a lot of cursing if you need to take it out and put it back frequently.
The bottom section is bracketed in the 4 corners but has a drop down centre piece for long loads, skis etc. The top piece is only bracketed at the top corners and secures its bottom edge to the top of the lower section of guard (if that makes sense) so if you removed the lower section completely, the top one would be flapping about. You could easily knock up some brackets to compensate I dare say.
That all said, it's a sturdy piece of kit and doesn't rattle or squeak unduly. I wouldn't be without it my 110 because I can load up to the roof now and not worry about everything flying forwards over me and the kids in the event of a sudden stop. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #63050 10th Mar 2011 7:37am
Post #63052 10th Mar 2011 7:46am
alantd
Nice mod Ken. That drawer system looks factory fit Thumbs Up One that started out as a 2.4 TDCi 110 XS
Post #63054 10th Mar 2011 7:53am
Markez79
ken wrote:
Sorry to resurrect this one, but how far does the cage encroach into the ‘boot’? Ie. How far behind the seats is it?
Thanks
Mark
Post #812054 26th Jan 2020 3:25pm
