Home > Maintenance & Modifications > Rear arch liners
grafty99
Rear arch liners
Has anyone bought these arch liners? Whilst very expensive for what the are - they do look good Thumbs Up
http://srs-tec.de/cars/Land-Rover/Defender...d=dbdkpkxr 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #630314 10th Jun 2017 10:06am
zsd-puma
Probably quite good if you drive on a lot of gravel roads. But little point for mud, Gwyn Lewis mudshields would be cheaper.
I think some of the Military ones just had a long flat piece of rubber bent into an arch in the wheel wells.
Post #630335 10th Jun 2017 12:08pm
grafty99
I do indeed drive a lot of gravel roads, the worst thing is our drive. It's compacted gravel and about 1/4 mile long, when you get out into the road the noise is pretty violent! Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #630340 10th Jun 2017 12:15pm
proloForêt
France 2008 Defender 90 Puma 2.4 XS CSW Java Black
This week I was under the defender changing springs and I wonders to myself how good a liner for the arches would be. I spent the first hour of work cleaning out mud, stones, leaves and a pieces of a dead bird from various places that a liner wold block. It is a shame that these are too much expensive for my budget but I will try to create my own idea solution.
Post #630347 10th Jun 2017 12:44pm
grafty99
Having seen the pictures again, I would say it would be fairly easy to make them yourself Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #630349 10th Jun 2017 12:47pm
proloForêt
I think that it's not necessary or good to use GRP like these company do. Why? Becuase the noise of the gravel hitting the GRP will be just as loud as the noise you want to kill. Semi-rigid rubber much better to work into the area in question.
I think a summer project for me later Very Happy
Post #630352 10th Jun 2017 12:55pm
VeeTee
Netherlands
I have had them, but removed them because a lot of dirt will get trapped between them and the body. This will keep these places dirty and moist, good for accelerated rot. I think it is best to keep things as open as possible so you can clean trapped dirt regurlarly and let things dry quickly. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #630353 10th Jun 2017 12:56pm
grafty99
That is definitely a point worth considering, however, I wash my defender at least weekly and have an industrial steam cleaner which I use once a month so I can get all the hidden dirt out where it likes to gather.
Another option is to make them easily removable by using twist lock clips like those on the fuel filter housing Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #630357 10th Jun 2017 1:22pm
Thon
I have a full set of Gwynn Lewis liners on my 110 and they cover all of the annoying nooks and crannies, and go some way to deadening the gravel pinging to the underside. They make cleaning much simpler for sure.
Post #630374 10th Jun 2017 3:14pm
zsd-puma
I'd definitely recomment the Gwyn Lewis shields.
I recon you could just fill in the bit above the wheel with a bit of rubber conveyor belt, that's the bit that's going to take the hammering from stones
Post #630446 10th Jun 2017 9:05pm
grafty99
I'll have to have a look when I get some time and see what I can come up with Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #630470 10th Jun 2017 10:44pm
