![]() | Home > Td5 > TD5 Nanocom injector question |
| MC84 Member Since: 23 May 2016 Location: Near Bristol Posts: 360
Hi, I have recently renewed my injector seals and washers. I know I have refitted the injectors in the same order they were removed so I thought I'd fire up the Nanocom to see if it would identify the injectors.
Within TD5 Engine settings I seem to have 3 different sets of listings for the injectors, none of which tie up with the ones fitted. The question is where is the Nanocom picking these up 3 sets of data from and can I confidently delete them and input the correct injector coding. I have the non-mapable ECU. I just don't want to mess things up!! Its been like this since I have had the Truck, over a year ago. These are mine, the ones below are given by the Nanocom Injectors No1 NHBEA No2 NFBDA No3 NDNNA No4 NLNGA No5 NDBCA NANOCOM - TD5ENG.APP - TD5 ENGINE settings file param;value Injector 1;NHBEM Injector 2;NFBDM Injector 3;NDNNM Injector 4;NLNGM Injector 5;NDBCM Accelerator;3 WAY NANOCOM - TD5ENG.APP - TD5 ENGINE settings file param;value Injector 1;NHBEC Injector 2;NFBDC Injector 3;NDNNC Injector 4;NLNGC Injector 5;NDBCC Accelerator;3 WAY NANOCOM - TD5ENG.APP - TD5 ENGINE settings file param;value Injector 1;NHBE0 Injector 2;NFBD0 Injector 3;NDNN0 Injector 4;NLNG0 Injector 5;NDBC0 Accelerator;3 WAY Thanks in advance Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
will engine start and run
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6728
I'm pretty sure the last letter (5th) isn't important on Td5 codes.
In your 3 sets of codes all the first 4 letters are the same for each injector. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
i will check my 03 plate ones tomorrow as i have the codes on paper havering replaced seal
Thanks for the quick reply's Guys. The Truck runs as well as it did when I had it, it's only since I read the numbers back from the Nanocom did the questions start!!
I will look at the info I've been told about on line in a while. I understand there is an idling tolerance which seems to be about plus or minus 3/4 across the range. Does this seem about right? Why do I have 3 different sets of values from the Nanocom? Thought I would only have one. Mike Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
