Home > Maintenance & Modifications > rough costs to fit rear discs and pads? (*** update done)
Stacey007
Hello
My 110 needs new rear pads and while they do this I'm thinking get the discs done also.
What would be the rough labour time on this job / or cost to do would you think?
(as a guide the garage (not a landy specialist) rang me to say the book time is 3.5hrs) sounded a long time? Its also a long time since I've done this sort of stuff but thought it's a fairly straightforward job?
Thanks #dont want to get ripped off
Post #629441 6th Jun 2017 12:53pm
Martin
Site Admin
Discs are trickier on a Defender than on cars, as the hub has to be removed from the stub axle. The discs are bolted on from the back.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #629442 6th Jun 2017 12:55pm
Stacey007
^ Thanks
He did mention that, I guess that is why the time (Labour) is pricey Thanks
Post #629447 6th Jun 2017 1:05pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
I book 3 hrs to do front and rears at work,
But in reality it's about 1/2 hour per disc. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #629449 6th Jun 2017 1:06pm
I fitted new pads to my rear axle yesterday, and the whole job including getting the tools out and putting them away afterwards, took about 30 minutes.
As noted above, disks are more involved but with the tools and parts on hand should add no more that about an hour in total to the above.
So at a main dealer expect to may for at least half an man-day of labour (so about £400 + VAT) plus parts, and be told that there are many other jobs that need doing. At a good indy, epxect to pay for about 2 man-hours (so about £100 +VAT) plus parts.
Post #629467 6th Jun 2017 1:46pm
Stacey007
^ Very useful Thank you.
It's only at a local garage for the MOT as I can drop it off their and walk to work. However on the way back I will drop into my local garage which know landy's more and ask them.
More awkward to drop it with them but I've a feeling it will save me money
Post #629468 6th Jun 2017 1:50pm
Stacey007
OK so I dropped the car off and then road the 7 miles to work Smile
Then rode back to find it was still being worked on..
While the bits were off I had the garage fit the wheel spacers, looks so so much better.
before
After
So total for fitting new cooper pipes rear to front both sides new brake pads, new discs and the wheel spacers £175. I supplied the parts at £80 (John Craddock) so £255 inc vat all in.
Bit better than the £408 inc vat I was going to be charged (and that wasn't even a main garage)
Thumbs Up
Post #630235 9th Jun 2017 7:10pm
Mo Murphy
But not as good as doing it yourself and saving the £175 you spent on labour 😊
50 Shades of Pennine Grey
Post #630236 9th Jun 2017 7:15pm
Stacey007
^ Your right even better but Time / Work / Kids I need this car running daily. Very Happy it does not have time to stop Thumbs Up
If it was my SIII then that would be different I would have a go.
Too be honest up on the ramps all wheels off and he was bleeding the brakes, it would be a lot more awkward with home ramps and my axel stands. Fitting the brake pipes would have been a pain also.
Some things I don't mind paying for. Even more so my dad said his last Range Rover Discs and pads fitted was just over £1000 !!!
PS, the £175 included the garage copper parts, which I guess would not be much but...included.
Post #630237 9th Jun 2017 7:20pm
