Home > Maintenance & Modifications > Brown rear demister element
BarnStormer
England 2008 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Hi, has anyone else noticed this? Mine (rear screen) was replaced last year under warranty as the element had browned off from white - the new on is now brown too! It works fine but maybe will burn out? Neutral First, Last - or Different!
2.4 90 SVX
Post #62940 9th Mar 2011 3:24pm
iruffell
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zambezi Silver
Mine is brown and the top 2 elements have failed, going to get it looked at when it goes in for a service later this month.
Post #62943 9th Mar 2011 5:06pm
Grockle
it's just discouleration due to the heat Thumbs Up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #63045 10th Mar 2011 5:24am
That's interesting my top two elements don't work either. It will go in to the dealer to be sorted out
Post #63055 10th Mar 2011 7:54am
dgardel
Italy
The wires are made with silver mix.
The heat developed from the wires make oxidation on itself Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #63061 10th Mar 2011 8:49am
DAZ110
Could be that the high level brake light rubs on the elements and wears it away! Crying or Very sad
Post #63066 10th Mar 2011 9:43am
mse
The top two stop for that reason - there is a fix for it! Mike
Post #63131 10th Mar 2011 5:42pm
dgardel
Italy
Absolutely not.....
but there is another problem..........
The problem is the 3rd stop tail rubber piece, probably it release rubber solvent that "eat" the heated element
Dealer changed me the rear windows two times.
Now I cutted (below) the rubber (5 on the figure) and make same sockets (where are 90° tracks curves and stop carries) for avoid contacts from the heating tracks and the rubber.
Now the problem IS solved...
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #63141 10th Mar 2011 6:23pm
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Mine has failed too... I noticed the other day, thought that I was seeing things.
Post #63189 10th Mar 2011 8:44pm
DAZ110
Both my heated rear screen element and the high level brake light element on the glass are broken. Big Cry
I had to run a wire up from the connector on the bottom right of the glass to to the high level brake light to get it to work.
Post #63205 10th Mar 2011 10:01pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Interesting.
had my rear window replaced under warranty. no questions, no drama.
also had my front screen changed as it was de-misting unevenly, left a strip down the middle of the drver side until last. now fine.
very impressed by the warranty service but by the sounds of it it seems a common problem on the rear window BM52
Post #63219 10th Mar 2011 11:09pm
BIGFOG
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
Hmm, my top two elements have failed as well, I mentioned it to my dealer who made a big thing of saying 'as it's for you sir, we will simply change the whole rear screen, just bring it in'. Perhaps they were not quite as generous as I first thought!!
Post #63223 10th Mar 2011 11:25pm
Grockle
as I posted many moons ago put some insulating tape on the 'rubbed' area to prevent it happening again Thumbs Up 2.4 90 XS
Post #63259 11th Mar 2011 10:51am
