![]() | Home > Puma (Tdci) > Dog guard (con't) |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3153 ![]() ![]() ![]() |
I asked about the dog guard and said no when told the price. I did manage to get a worklight for a bit less than your quote though... 2011 110 USW
1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
remember dealers are there to be beaten down, the tow bar with elec is only �250 and that is rated for a hell of a lot more than a dog guard.
inthedesert Member Since: 07 Mar 2011 Location: ireland Posts: 19 ![]() |
I fitted the LR dog guard in my hardtop; it was easy enough and took less than an hour. I couldn't bring myself to drill the roof fixings, but it's solid without.
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
See my post on your previous thread.
Buy it yourself, fit it yourself. If things have to be 'adjusted' do you want someone who cares about the end result doing it or someone who is under the cosh to get it done in 10 mins? The dealers are good for some things - obviously anything that affects warranty - but is is a job for you, a spanner, maybe a vice and a cup of tea ![]() + New Defender 110 First Edition |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Alan, you forgot the plasters and the requisite teddy bear, which you will need to rip the head off to calm you down when it still wont fit after the third attempt ![]() Don't worry though GN, it will fit on the fourth attempt as you will make it FIT!!!!!!!!!!!! |
