![]() | Home > Tdi > R380 300 tdi gear box mounts |
These can either be a pain or easy to do, the best way is to support it on a jack, loosen everything off to free the mounts, raising/lowering as needed. The rebuild is the same everything together loose and then have fun trying to align it al. It's not a hard job but can test the patience for some people.
Take your time with plenty of brews and you will be fine. ![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5354 ![]() ![]() |
Thanks mash, looks like its a weekend job and a half then. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 ![]() ![]() |
The genuine mounts are quite soft so it is possible to manhandle them a bit to get them into position, watch out for the razor sharp edges of the heat shield on the exhaust side mounting though.
