Home > Td5 > TD5 steering column
seadogdjh
United Kingdom 1999 Defender 110 Td5 SW Epsom Green
TD5 steering column
Hi all, just posted the below in the my defender thread
It was at this point realised something not right.
When ordered online had already been in contact with the supplier on the phone to confirm was correct boss (48 spline) with regards to chassis number which is an xa. After phoning them to double check was correct for 48 spline, went to count the splines..... 36! Any body else had a similar problem? Office closed but shall be in touch first thing on morning to get the other one sent out and then update on here
Is regarding a mounteny steering boss and wheel. Seems the number of splines is different to what should be.... It's a t plate 99 td5 chassis xa.
Any thoughts? Cheers in advance Wink
Post #627130 26th May 2017 10:00pm
Martin
Site Admin
At that age the factory body type matters and determined which column + wheel it received at the factory. Station Wagons got one type (36) and everything else the other (4Cool
http://www.web-rover.co.uk/articles-steeringwheels.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #627139 26th May 2017 10:40pm
Martin
Site Admin
That should be ( 48 ) not (4Cool
Going on your vehicle profile saved here you have a 110 station wagon so 36 spline is correct.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #627141 26th May 2017 10:41pm
seadogdjh
That's great to read that there's an explanation for this, many thanks Thumbs Up
Post #627148 26th May 2017 11:27pm
seadogdjh
Ok, so got the correct mountney boss, however was not at all happy with the finish or detailing (see if can spot their mistake!!)
Decided to go for something of what should (hopefully) be better quality and ordered a momo tuner wheel and 36 spline momo boss which the supplier said would fit ok.
Have read other threads on here but couldn't see anything specific to model and year of mine. 99 td5 110 county station wagon.
Has anyone with same spec fitted such a boss as below. It just does not fit very far down the splines and butts up against the steering housing.
It does have an indicator cancel pin but just the one.
Has anyone fitted such a boss to a similar spec vehicle and were any modifications needed to get this to fit and work correctly, any help greatly appreciated Wink
Post #628459 2nd Jun 2017 1:40pm
seadogdjh
....Sorry, or do i need a different boss???.... Again Embarassed Laughing
Post #628466 2nd Jun 2017 2:04pm
seadogdjh
So got it fitted, really happy with the look.
Got the ignition on and gave it a few turns, the problem is there is no clearance between the back of the boss and the steering cowling i think you'd call it, think the creaking noises may do my nut in, not that there's already a few to contend with haha it being what it is Wink
Other concern is that there is only approx 3 or 4 mm of the splined shaft binding with the splines on the boss.
Still looking for any guidance or advice on any possible improvements
Post #628524 2nd Jun 2017 6:13pm
seadogdjh
Aha! Is this what people have used over the momo one?
http://www.exmoortrim.co.uk/land-rover-36-spline-boss-kit.html
Looks like it may give some clearance and yet more of the splines be allowed to bind
Post #628568 2nd Jun 2017 9:14pm
seadogdjh
Ok so got an exmoor boss and got it fitted. Not 100% happy with it though, but it shall have to do for now.
The wheel looks great but the finish of the boss and it's final position is quite proud.
Shall do more homework and change the boss at least when it finally gets a rebuild.
Post #629909 8th Jun 2017 12:23pm
