Home > Maintenance & Modifications > Best paint for rear cross member
Leeroy
United Kingdom 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
Hi Guys I am sure this has been covered before but can anyone help and provide the details for quality products for me to prep and spray my rear cross member and any tip or advice would be much appreciated.
I did have a wobble and was going to sell it las month but bought the wife a new car so didn’t have let it go Very Happy
Thanks in advance
Lee
Post #626950 26th May 2017 9:30am
Rallymental
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Santorini Black
Try this
http://www.defender2.net/forum/topic52858....mber+paint The definition of insanity is doing the same thing over and over again but expecting different results.
Solihull, 1948 - "If we paint the chassis, it will last for years"
Solihull, 2015 - "If we paint the chassis.............................
Post #626953 26th May 2017 9:41am
Leeroy
Rallymental
Thanks for link I have just looked on the website and was thinking Satin out of the 3 choices what did you go for?
Lee
Post #626973 26th May 2017 12:06pm
Rallymental
Sorry Leeroy, I haven't actually done it myself, my defender being only 2. I've just liberally coated mine with acf50.
But all that having been said I think you're right, satin is a good choice. The definition of insanity is doing the same thing over and over again but expecting different results.
Post #626975 26th May 2017 12:23pm
Leeroy
Rallymental no worries the product looks really good looking forward to sorting it out it the only thing that lets it down.
Lee
Post #627025 26th May 2017 4:02pm
Riverboy
2014 Defender 90 Puma 2.2 SW Corris Grey
Is it really a good idea to paint the rear cross member? Does it actually prevent rust or just hide it? I just give mine a good spray and wipe over with ACF50 after each wash. Would it be better to have it professionally painted instead?
Post #627042 26th May 2017 4:41pm
zsd-puma
If you clean the rust off first then paint it it's fine. Don't just paint over rust though.
I rubbed mine down and painted it with a few coats of Zinc-182 primer then Upol satin black top coat. Came out a treat, still looks perfect after a winter.
Post #627046 26th May 2017 4:46pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Riverboy
I wiped mine over with ACF50 after each wash too, however the paint is so thin that it more or less washes off allowing spots of surface rust to develop. I'm waiting for a warranty repair to put it right but according to the body shop manager JLR's solution is to scuff it back and blast a coat of satin black over it to make it look ok.
I'm in the process of exploring the best coating for mine too Thumbs Up 2014 110 2.2TDCi XS Station wagon - GONE
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - GONE
2024 110 D250 X-Dynamic HSE
Post #627068 26th May 2017 5:55pm
Riverboy
It just concerns me that once painted you may not spot corrosion until its too far gone. Our other 90 has a painted cross member and it worries my why it was done and what its hiding. Is it known why Land Rover left it as it is? It seems odd.
I ACF50 the hell out of mine, and had it Dinitroled by Zagato last year. I'm hoping the dryer hotter climate down here is a bit less conducive to rust.
Post #627070 26th May 2017 6:00pm
jomara
As long as it's prepared an treated properly before painting there should be no issues.
This is typical Land Rover penny pinching, the painting of the chassis is carried out by the subcontractors who manufacture them and as with all components it's all down to lowest cost per unit which is why they don't fit galvanised chassis or even coat the standard chassis with a more hardwearing paint. 2014 110 2.2TDCi XS Station wagon - GONE
Post #627072 26th May 2017 6:06pm
zsd-puma
the problem with the cross member is the paint gets broken down by the UV, it fairs a lot better in more shaded areas like the chassis rails. It's crazy they didn't offer a galv chassis as at least a massively over priced factory option.
But yes if it's prepped and painted properly it wont corrode. Salt is what really eats away at them, so if you're in a warmer climate corrosion is much less of a worry. But painted steel will always last better than bare steel.
Post #627080 26th May 2017 6:39pm
Riverboy
Out of interest. What sort of money are we talking for a galvanized chassis fitted? I cant imagine they would do that here so its a return to UK job. Rolling Eyes
Post #627081 26th May 2017 6:44pm
zsd-puma
I think the chassis is a couple of thousand pounds just to buy. But any competent garage could fit it, it's just time consuming to fit. It's just a big Meccano kit.
Post #627084 26th May 2017 6:47pm
Riverboy
Well maybe in the future if the need arises. Mine is a keeper and I'll do whatever it takes to keep it as mint as possible.
Post #627085 26th May 2017 6:49pm
sako243
As was recommended in the other thread Buzzweld products appear to be the way to go.
I put a Hi-Lift jack through my cross member last summer and had a custom one built up a-la Black Sheep but better Whistle. I simply gave it a coat of RCP and a coat of CIO. It's been smacked a couple of times off-road and the paint is untouched and never washed since going on 9 months ago.
Time will tell how it lasts but so far it's outlasted Hammerite by a factor of three... Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #627111 26th May 2017 8:37pm
