Home > Maintenance & Modifications > Saftey Devices Roll Cage....... |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
Looks like all the cage companies are doing bad jobs at the moment.
My SD cage slotted on a treat and the Powder coating is still fine after 6 months (no signs of cracking etc). Glyn |
13th Feb 2011 3:28pm |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2642 |
I've just purchased a North Offroad cage for my challenge truck. Came in kit form, painted in primer. All notches are good. Comes with all the relevant nuts and bolts. At the same time I've got a set of their challenge wings. They even come with the bonnet pins needed.
Will be getting it glued together in about 3 weeks time. Will let you know how I get on 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
13th Feb 2011 4:09pm |
Mike_B Member Since: 23 Jan 2011 Location: Moray Posts: 550 |
Not all of them. just had a Whitbread cage fitted to my 110 csw. Fit is really good. Designed to my drawings, no problems. Its fully welded, so you wont get rust dripping all over the bonnet. The welding means its more difficult to steal too. Paint is good and easy to touch up if required. |
7th Mar 2011 8:16pm |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 980 |
Yes Mike, my Whitbread cage is in Smoothrite Black!
Merlin |
8th Mar 2011 10:41pm |
Toplink Member Since: 05 Dec 2010 Location: Somerset Posts: 159 |
Just finnished fitting roll cage.
I had to weld the chassis brakets ,as the holes to bolt it to don't exist! I had to use a lot of bolts and washers that were not supplied. I had to move the fuel filter as its in the way of the under chassis bar. The recommended position of holes is a fairy story. I think that the designers at Safety Devices need a kick up the arse because they haven't changed the design since the 300 tdi chassis. That only went out of production over 10 years ago. Hey ho finnished now if you fit one to a 2007 defender allow a week to fit and remanufacture bits to fit. Its never over in my land rover. 2007 Defender HTop. 1952 Series One 80" 1977 Muir-Hill 111. 2014 Triumph Tiger800xc 1999 Discovery 2 td5 1982 Ransomes TSR300D. 2002 Yamaha XT600e. 2010 Freelander2 (the wifes) 2008 John Deere X140 |
13th Mar 2011 3:19pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5024 |
Probably relates to the move of production abroad! Mike
13th Mar 2011 4:44pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
Good old poles |
13th Mar 2011 5:04pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6044 |
Got any piccies?
13th Mar 2011 7:10pm |
I will sort out some pics.
If I had know they were now made in Poland I would have gone elsewhere. Its never over in my land rover. 2007 Defender HTop. 1952 Series One 80" 1977 Muir-Hill 111. 2014 Triumph Tiger800xc 1999 Discovery 2 td5 1982 Ransomes TSR300D. 2002 Yamaha XT600e. 2010 Freelander2 (the wifes) 2008 John Deere X140 |
13th Mar 2011 8:31pm |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 |
Hi Just had a quote from them ... much cheaper than a SD one ... What's your opinion about it ? Are you satisfied ? shiping, finishing, easy to fit ? placed a post the other day on another topic but got no answer ... Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
13th Mar 2011 8:59pm |
they moved to Poland after they went bust in 2005. Cheaper overheads! |
13th Mar 2011 9:08pm |
I am extremely happy with my Whitbread roll cage. I would recommend them. The only criticism is that the paint job doesn’t survive a tough day greenlaning, hence the Hammerite Smooth. If I bought another one I’d go for galvanised. They made it to order and fitted it in a day.
Merlin |
14th Mar 2011 7:48pm |
