![]() | Home > Maintenance & Modifications > 2007 puma seal below windscreen leaking |
Les Member Since: 20 Oct 2015 Location: Aberdeen Posts: 8 ![]() ![]() |
Thanks
Looks like test L and apply clear sealant on the outside of the seal I'll try at weekend |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 726 ![]() ![]() ![]() |
I ran a bead of Sikaflex along mine and it's not leaked since. Put a dob behind the windscreen hinge brackets as a precaution also.
Personally I wouldn't use silicon, it's horrible to remove totally if you want to re-paint the vehicle at a later date. |
Thanks
Was that along the outside of the seal? I guess you can buy clear - its a grey defender |
Sikaflex in black
julianf7 Member Since: 08 Mar 2017 Location: Aberdeenshire Posts: 11 ![]() ![]() |
Apologies for the newbie question, but which Sikaflex do you recommend here? There are so many types from which to choose..
Sikaflex 291i Marine Adhesive & Sealant in gray too
https://www.defender2.net/gallery/albums/u...281%29.pdf |
Many thanks, ordered it up
I used the same stuff as Dorsetsmith and no complaints so far. Mask the area externally before you apply the Sikaflex then wipe excess off with a wet finger before removing the masking. You can paint over the 291i version as well ![]() |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Just a little story... I thought this was my leak too but it turns out it was actually the seal between the windshield frame and the roof !
The water would run a small way along the 'inside' gutter (behind the roof trim where the cables run) then down a piece of the roof casting on to the door seal then down the inside of the door seal behind the plastic trim of the A-pillar until it hit the seal you're taking about then do it's drippy thing... Solved the bowel problem, working on the consonants... |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
If you're going to use sikaflex type stuff, use one that' over paintable, anything else is likely to cause massive problems should you wish to do any painting later on.
I've used some of this on mine... http://www.ebay.co.uk/itm/171234457522 Worked a treat. |
