Home > Maintenance & Modifications > MAF cleaning spray. Worth it? Then pilot correction?
agentmulder
Kuwait
Gidday,
So I've seen various brands of MAF specific cleaners about. All aerosol, and all quite expensive when compared to other solvents like brake cleaner, contact cleaner etc.
They typically state 'HP increase!' and so on ..
I've had a read about the MAF, and it stands to reason that a sensor giving falsely low readings (assuming a dirty wire will take longer to cool than a clean one) isn't going to be the best situation.
I don't want to hazard a guess as to what the ECU will make of it - but let's just assume it'll be less efficient.
So, I'm keen to try it. Aside from general discussion regarding these cleaners i have a specific question:
Will a pilot direction relearn be a good next step? I did that with the VCV swap, and considering that the sensors are all involved in the lead up to the same process (combustion)... Yeah?
The relearn might settle on a different (better) set of values considering the MAF is now giving more accurate readings?
This is on 2.4 puma, with Stage 1 BAS remap. MAF never cleaned, never had apparent issues .. Solved the bowel problem, working on the consonants...
Post #626510 24th May 2017 4:02am
Morepower
New Zealand
You shouldn't need to re-set anything, The ECU should automatically correct for any small changes in the MAF readings...
Regards
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #626539 24th May 2017 9:09am
agentmulder
Kuwait
I would have thought it would be calibrated for a clean wire and then progressively read lower than actual air flow, then go back to 'normal' upon cleaning?
Or in other words it'll correct when cleaned, but not as it's getting dirty.
? Solved the bowel problem, working on the consonants...
Post #626542 24th May 2017 9:17am
Morepower
New Zealand
The MAF will be designed to read over various conditions, All the happens is when they get dirty they take an 'offset' that can mean that the airflow measured won't match the actual airflow... By cleaning it, It should loose the offset (if it has one)... However, please be careful as it's very easy to damage a MAF....
Regards
Post #626544 24th May 2017 9:27am
Naks
I just use carb cleaner, no issues. --
Post #626545 24th May 2017 9:28am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Carb cleaner, brake cleaner, any solvent based cleaner that will remove oil based deposits.
As said, ecu will revert back to normal conditions after cleaning, you don't get re learn options for either MAF or MAP sensors. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #626552 24th May 2017 10:11am
http://www.ebay.co.uk/itm/Holts-Brake-And-...SwbqpT6gNH
That'll do you for next to no cost, I've done this just a few weeks ago with the MAP and MAF and you WILL notice the difference in performance.
Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #626589 24th May 2017 2:06pm
agentmulder
Kuwait
My intention was more that the pilot correction relearn would relearn the settings related to pilot correction, but in the new context of a cleaner MAF.
(I relearned last with a dirtier one)
Anyhoo, did this today, the solvent was the actual stuff, CRC brand - on special Mr. Green
While I'm well aware of my propensity for confirmation bias, I'll still say it 'felt' like things were improved, sounded smoother, the engine was having a good day, if you know what I mean Shocked Laughing Solved the bowel problem, working on the consonants...
Post #628612 3rd Jun 2017 5:17am
JustFX
United Kingdom 2000 Defender 110 Td5 CSW Coniston Green
The technology in the MAF is a form of a hot wire anemometer[1]. The wire is heated and the drop in temp is measured. The wire is often very thin and prone to damage.
If it gets coated in oil/dirt then that will insulate it slightly and give you lower airflow readings.
A quick clean with some solvent on a regular basis is wise.
Jack
[1]https://en.wikipedia.org/wiki/Anemometer[2]
[2]https://en.wikipedia.org/wiki/Thermal_mass_flow_meter
Post #628654 3rd Jun 2017 12:01pm
