![]() | Home > Maintenance & Modifications > 110 Brake upgrade |
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 ![]() ![]() |
The Bowler brake upgrade will fit inside the Bowler 16" wheels... You'd have to ask Jon @ Bowler if it would fit with other wheels.... However, At £4200 inc VAT it's not what you'd call a budget option...
The Std System is pretty good however, You just need to keep everything in top condition... I had HEL Performance make me some braided brake lines for the 110 and that improved the pedal feel... I have also rebuilt the brake system in the 30k miles that the 110 has covered as there was a drop off in brake performance during the 3rd year... This was just down to normal wear and tear, However the rear caliper pistons where showing signs of the dreaded rusty pistons... FYI when I rebuilt the brake system I replaced everything, Disk's, Pads, Calipers... All with Genuine LR parts Hope this helps Regards Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2217 ![]() ![]() ![]() |
I would start with fitting new front callipers (depending on age), slotted (not drilled) discs - Should slow down and brake fade and keep the pads in tip top shape (Often towing heavy loads would warrant the upgrade imo) braided lines as mentioned, brand new brake fluid and a full pressure bleed. Then fit some Ferrodo or Blueprint pads and the brakes should be as good as they are going to get in relative standard form.
Other than that youve got Bowler as above for £4k, AP for £3k or Alcon for £2.5k but the last two require 18" wheels, which would also mean new and expensive tyres! Don't forget Defenders where designed with towing in mind ( to a degree) so the standard system should be well up to the job. |
I've heard before the braided hoses make an improvement in terms of pedal feel which in my opinion isn't confidence inspiring in standard form.
It's also been suggested the standard brakes are pretty ok so I guess I need to get some new hoses and fluid on order ![]() good luck in finding the right solution. please keep us posted on progress ![]() |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 ![]() ![]() ![]() |
There shouldn't be a problem, if he gets a set of pagid discs/pads + new fluid and braided hoses and there's still a problem... then either the master cylinder or servo are not doing their job. 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top 1958 Series 1 Soft-top |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1648 ![]() ![]() |
The only reason why you would want a brake upgrade on a Defender is... because big brakes look cool!
![]() The standard brakes are more than adequate I believe, even if you are towing 3.5T down Mt Everest! YOLO... You Only Live Once... |
Avelingporter Member Since: 25 Jan 2016 Location: Southampton Posts: 407 ![]() ![]() ![]() |
Thanks for the replies. Seems good pads, new fluids and braided hoses are the way to go.
Thx , Douglas |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
It also helps if the brakes on the trailer(s) serviced. A fully loaded 3.5t trailer with poor brakes is going to be a pig to stop no matter how good the brakes on the tow car are.
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 ![]() ![]() |
If you keep the standard set-up in good order, and as ZSD says, have a decent set of brakes on the trailer, plus driving within speed limits I don't think he'll go far wrong. I see so many people towing way too fast for the loads they're pulling it's scary.
On a side note, I had to refurb all of my calipers and it turned out that Zeus Stainless pistons were cheaper than genuine, and if what I hear is correct, genuine parts aren't all that they used to be. |
I wasnt going to bother with new pistons and seals, was just going to buy a pair of new callipers for £80 cheaper and much less work!
Definitely cheaper and less work I agree, but as I say, the quality of the brakes has dropped significantly. My old '84 90 hard top was on its original brake calipers after 23 years and still fine, the Puma's managed just 10 and were toast.
Poor show!!
Bloody right poor show - they weren't just a bit flaky, they were ruined, and it had done maybe 35K at that point. I was well peeved but mine had spent most of its life standing in a lean-to and inactivity also creates its own problems, of which this was just one.
I've heard that all manner of genuine parts are affected by this general quality deterioration, from drive flanges to brakes to door seals, and these are just the things I have come across in the last 18 months. |
