![]() | Home > For Sale & Wanted > SCHEELMAN seats FULL LEATHER SPECIAL OFFER |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
But the price is for a single seat or for a pair? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
| nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546
Always per seat! WANTED:
SII or SIII in max 1.5k |
Ahaaaaaa.....
Martin, do you want same photos of my Sheelmann? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
By the way, my door seals is arrived (two weeks ago
old ones out, new ones in thats it. No diploma in rocket science needed
But why did it take 2 weeks until you want to fit them? WANTED: SII or SIII in max 1.5k |
no silicon on the corner or other stuff??? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
no free time, busy for job travels from monday to friday... during weekend "family meetings"..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
Usually nothing else needed. And if: NO SILICONE! NEVER! I contains acid which is highly corrosive! Use PU or some permanent elastic for automotive use.... WANTED:
| szracer Member Since: 10 Oct 2010 Location: Cotswolds Posts: 356
Fitted my seals a few weeks ago, but find them a bit 'squeaky' now. Any suggestions for how to reduce the squeaks? Sorry to hijack this thread!
2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
no problem
You can use silicone or PTFE spray or talcum powder. Or there is a special rubber treatmen you can find in automotive shops. How is sqeaky exactly meant? WANTED: SII or SIII in max 1.5k |
| jerseyman Member Since: 21 Jul 2009 Location: Jersey Posts: 279 |
I knew that this will happen
Silicone sealing compound (for bathtubs etc.): contains ethanoic acid Silicone lubricant: acid free WANTED: SII or SIII in max 1.5k |
Thanks Peter,
After careful examination (I originally thought the squeaking sound was from the door rubbing on the 'new' inner lip of the seal), it is coming from the top part of the door rubbing on the outer seal. Guess our Defenders have as much structural rigidity as a lettuce leaf, so I shouldn't be surprised! Anyway, back to the seats......
This is ocasionally possible. Just press the seal a little bit up or lower the door slightly.
"structural rigidity as a lettuce leaf" SII or SIII in max 1.5k |
