![]() | Home > Technical > 2005 TD5 possible Clutch slip in 5th at 30mph |
Retrostu Member Since: 03 Feb 2016 Location: Kent (AKA Garden of England) Posts: 128 ![]() ![]() ![]() |
Sorry to be a pain but on way home I over took a scooter at 30 mph I was on the flat without gradient but I was in 5th (lazy me I know) as I accelerated past him my clutch seemed to slip when the boost came on then settle when up to speed, then again when I took my foot off of the throttle and then floored it same thing again?.
Didn't happen in 4th when I dropped it down and floored it either?. My truck has been remapped about a year ago but I've never noticed this problem before. Only done 56k miles!!! I did have it serviced last weeekend but neither the clutch or gearbox oil was touched. Any advice please. It's more important to concentrate on what's ahead of you than what you have left behind. This is what I keep watching to remind me why I own/keep my Defender. https://youtu.be/x4DZgOcgn1s |
LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11240 ![]() ![]() ![]() |
Yes, it's entirely possible, particularly since you've had it re-mapped. Essentially, the torque of the engine is overcoming the grip of the clutch plate due to the excessive load you put on it. The high gearing in 5th means the load resistance to move the vehicle is greater.
The easy solution is to not be so lazy with changing down a gear, but if the problem persists then it's possible that you've exposed a wear problem with the clutch. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
ok thanks for your advice, I'll get my coat. It's more important to concentrate on what's ahead of you than what you have left behind.
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
You need a new clutch I've got the hd1 ceramic clutch from Ben at clutchfix and it's superb 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
Oh great! Someone has also told me to adjust the clutch pedal too now I'm proper miffed.
Also checked fuel pressure regulator and no leaks onto bell housing dry as a bone so now maybe adjust clutch pedal first?. But cheers pj2106 for the suggestion of the clutch I'll make a note if it ![]() This is what I keep watching to remind me why I own/keep my Defender. https://youtu.be/x4DZgOcgn1s |
