![]() | Home > Td5 > Is it ok to drive without the front prop shaft ? |
Defender marto Member Since: 14 Mar 2016 Location: Wirral Posts: 128 ![]() ![]() ![]() |
This is turning out to be quite an informative thread. Thanks guys.
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
I recently took off my front and in the process marked the flanges to assist later, but when reinstalling I questioned what exactly I had achieved... If I installed one end 180deg out (rotating TF box) what actually happens to decrease stability? If I recall, the guiding boss/spigot (whatchamacallit) wasn't tapered either so the eventual axial alignment will be determined by the (non-zero) bolt tolerances... Keen to learn! 👍 Solved the bowel problem, working on the consonants... |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17831 ![]() ![]() ![]() |
You missed out an inmportant part of my statement in your quote:
If you take the flange off the propshaft you could have balance issues. If you take the propshaft off the vehicle but don't dismantle the propshaft itself, it doesn't matter how you refit it (provided you don't swap it over end-to-end, I suppose) since it was randomly fitted on initial assembly. In your scenario it won't make the slightest difference. |
Ahhhh, yes, my bad, I see what you're saying
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8303 ![]() ![]() ![]() |
try fitting it with one UJ leading the other by one notch on the slider. Cheers
I have brought a new prop shaft now and the slider part slides so much more easy than the old one which is still very still to move. The new one unlike the old one is out of phase which if I have read right mean it balanced better that way. I'll fit it this weekend and let you all know how it went.
IT won't affect the balance as such but should improve the cyclic acceleration/deceleration which you'd otherwise get and therefore reduce vibration.
