Home > Maintenance & Modifications > Unwin cargo rails fitted.
Baz8046
United Kingdom 2002 Defender 90 Td5 HT Rutland Red
After getting tired of everything in the back rolling around I decided to fit some cargo rails at the weekend.
Unwin seemed a good choice and are widely available.
You can then get the cargo loops that will fit anywhere on the rail.
There is also a rubber cover that slots in when they are not in use to stop anything catching in the rail.
The only down side is you have to drill a few more holes in the floor but not the end of the world.
I drilled mine straight through the floor mat and will trim the bolts underneath when I get chance.
 Defender Td5 Commercial 2002
Range Rover L322 TDV8 Westminster 2012
Discovery 4 SDV6 Landmark 2016
Post #624710 16th May 2017 8:07pm
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
"M" bolt size ...
What size & length bolts did you use?
Thanks.
Post #624793 17th May 2017 8:55am
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
Same style of tracking used in our Ambulances, it takes a good beating and lasts for years. I've only ever seen it wear out on one vehicle - the mechanic just turned it round and put the worn end at the front of the saloon and put the unused end at the back of the vehicle where all the chairs etc get clamped to. If you need that sort of thing it will serve you well. Just make sure there are no wee stones etc in the track or your clamps etc won't go in.
Post #624908 17th May 2017 5:29pm
Baz8046
The bolts were M8 x 75mm with counter sunk heads to fit the rail.
They are too long for just bolting through the floor but are just right when you have to go through a a strengthener.
I bought the bolts with the rail as a kit.
The rails and bolts were about £60 and the fixing rings an extra £20. Defender Td5 Commercial 2002
Post #624993 17th May 2017 9:35pm
