Home > For Sale & Wanted > [Wanted] Slick Shift
barrowg
United Kingdom 1990 Defender 90 200 Tdi HT Corris Grey
Hi all,
Anyone happen to have one of these for a lt77, think they're for both gearboxes, so doesn't really matter. On a tight budget so need a good offer and needs to have all parts, as don't have the time to be chasing parts before the beauty is back on the road. Heard they make a massive difference to finding the gears. Got an old 1990 thats almost impossible for the rest of the family to drive after all driving these silly new cars. Any help on how easy it actually makes it to change gear is kindly appreciated cheers.
TIA
George
Post #604010 22nd Feb 2017 9:37pm
barrowg
bump
Post #624693 16th May 2017 8:12pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
George,
I was thinking about going down the Slick Shift route and watched the Youtube fitting videos.
Once i'd watched them I thought I would check the bias springs to see if they were set correctly. Needless to say they weren't so 5 minutes later and as if by magic they were. I've stopped thinking about Slick Shift for the time being as the gears are so much easier to find now.
Regards
Phil 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #624714 16th May 2017 9:15pm
barrowg
Hi Phil,
Thanks for the advice I'll have a look when I'm home
Post #624737 16th May 2017 10:46pm
Green Machine
George,
Just to point out that the Slickshift makes no difference to the actual selector mechanism itself, it just shortens the throw of the gear lever. So if the mechanism is worn, it will still be worn with the Slickshift fitted (albeit with less movement of the gear lever).
Having said that, the Slickshift does make a big difference to general driveability, with much less movement of the lever to select gears, and I rate it as one of the best things I have done to my Td5, but my gearbox was already good with easy gear selection before the Slickshift was fitted.
As Phil says, if 3rd and 4th are difficult to find, check your bias springs are set up correctly. These centre the gear lever in the 3rd / 4th gate. When set correctly you should just push the lever straight up for 3rd and straight down for 4th, if you have to move it sideways at all your bias springs need adjusting. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #624809 17th May 2017 11:37am
