Home > Off Topic > Rig Pictures
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Rig Pictures
For your general Interest
Dundee
Offshore over platform
 Original Member Pie n Pea Club.
110 HCPU Tipper
Post #62455 6th Mar 2011 11:38am
AndrewS
Cool
Ive not had anything to do with rigs. So from the pictures I gather that the 'Rig' travels out to a 'Platform'? If so are there various 'platforms' sat waiting to be drilled or are the platforms over old or empty oil fields? 130's have feeling's as well you know Smile
Post #62461 6th Mar 2011 11:51am
willy eckerslike
Some platforms have a drilling package built in and do their own drilling and workover, just hiring a firm that provides labour etc. But alot are too small or the drilling package has been removed. With the newer generation Jack up Drilling rigs they can skid out their drilling derrick up to 90' aft of the transom, also transversing side to side. They can then drill either new wells in empty slots or re-utilise old slots by sidetracking the existing well. The rig can also change out the existing production (completion) equipment in existing wells that have failed tubing or failed pumps. Alot of smaller Oil firms are buying up the older assets and with new 4D seismic are finding small pockets of oil and drilling new sidetracks into the new targets. Mostly now we run electric pumps (ESP's) into the wells once complete as the formation pressure has fallen below that needed for the well to flow naturally. The rig actually floats and is towed out to the site, we then run anchors and with the aid of the tugs position it alongside (often as close as 1-2m) then pin in position with the legs. Jack the hull out of the water, test the sea bed by filling up with water, then jack up to working height.
New platforms generally have the wells pre-drilled over a template, then put the platform in place, then the rig comes and ties them back to surface and runs completion equipment. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #62465 6th Mar 2011 12:08pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Very interesting Willy Thumbs Up
I think it would be a bit cold for me though out there Embarassed NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #62467 6th Mar 2011 12:15pm
willy eckerslike
When I say float Whistle
110 HCPU Tipper
Post #62470 6th Mar 2011 12:30pm
willy eckerslike
Close Shave Shocked
110 HCPU Tipper
Post #62471 6th Mar 2011 12:37pm
AndrewS
Easier than getting the mop out to clean the deck Thumbs Up 130's have feeling's as well you know Smile
Post #62480 6th Mar 2011 1:53pm
BigRuss
I'll load some pics when I got home of fixed drilling platforms Thumbs Up Russell
2011MY 110 XS USW Black
Post #62481 6th Mar 2011 2:10pm
BigRuss
Just to follow on from Willie's her are some fixed platfroms with drilling rigs onboard.
This is Brent Charlie and Brent Delta in the background, there's team in the office above me working on the Delta Decommissioning. Photo taked from Brent Bravo
These are a couple for Norwigen rigs pos Troll A/B. Photo also taken from Brent Brave which is only a few miles from Norwigen waters
This is the Tern Alpha drilling derrick undergoing a referbishment last year. I was on the fingerboard.
One of 4 CAT D-Mag engines that are used to provide electrical power to the Brent Alpha drilling package.
In order to get to the rigs in the photos you have to board a fixed wing from Aberdeen to an old second world war airbase in the Shetlands calles Scatsta and then they are between 45minute to 90minutes chopper ride dependant on the choppers routing. In total it takes between 3-4 hours to reach them in good weather from the time you check in. And when you get a checkin time say 05:30 am it means you turn up to checkin at 05:30 am none of this be there an hour before crap. Russell
Post #62490 6th Mar 2011 4:07pm
mick
Hope you had your lifesaver on Thumbs Up
Its nice to see what others do to earn a shilling as well.
Post #62520 6th Mar 2011 7:19pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
Is this the power plant for the new defender 2012 Bow down Bow down Bow down
Post #62521 6th Mar 2011 7:26pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
out of interest do the generators run off fuel shipped out to the rig or do they use the waste gas you see being burnt off? BM52
Post #62522 6th Mar 2011 7:31pm
s18mcn
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
kingofthesparks Out of intrest you dont know someone called BOB BROWNING do you?
Post #62532 6th Mar 2011 8:18pm
BigRuss
They are diesel driven which is shipped out.
Mounted on to the other end of each engine is a 1 meter square alternator Very Happy Russell
Post #62534 6th Mar 2011 8:26pm
willy eckerslike
Thats a baby, I'll get some pictures of a proper one tomorrow Rolling with laughter , Alot of the early diesels were dual fuel and could run on gas or heavy oil. Most of the platforms run turbines that mostly run produced gas occaisonally switching to diesel.
The rig we have on hire currently burns around 5000 gals diesel per day dependant on how much equipment we are using.
Some Stats, the block is currently reaved with 10 lines on 1 7/8" line and can pull 1,600,000lbs with three 1000hp shunt motors, the top drive is 1600 hp and can turn pipe up to 120 to 200rpm and 60,000lbs torque continuous, The mud pumps are 4 x 2200 HP and can pump at +/- 500 gal /min each at up to 7400psi. We can rack back 30,000 ft of Drill pipe weighing +/- 600,000 lbs.
It's just a big toy Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #62543 6th Mar 2011 9:01pm
