![]() | Home > Td5 > 110 TD5 High Capacity refurb |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
if you're scrapping the chassis you can always cut some extra holes in it to help pull the loom back through if need be.
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 672 ![]() ![]() ![]() |
I was repairing (welding) rear parts of 130 chassis. First I have pulled the loom from chassis, to protect from heat. After repair, I have placed the loon on the top of chassis, not inside. It was much easier, and it will not restrict later cleaning of the chassis internals. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
Hawksthorn Member Since: 10 Jan 2017 Location: Gloucestershire Posts: 34 ![]() ![]() ![]() |
Many thanks guys.
Regards David |
The loom is out , disconnect and pull through into cab. With the chassis it was pulled from the rear and out along with a couple of kilos of Somerset silt.
corgi1 Member Since: 26 Feb 2017 Location: bucks Posts: 440 ![]() ![]() ![]() |
we need pictures all the way ITS THE LAW !
I agree many pictures all the way through the process please
![]() My build thread http://www.defender2.net/forum/topic17615.html |
