Home > Technical > Hazards lights/ indicator issue
lb73
Wales
Just going through the snagging list before the mot on my 99 110 csw 300tdi. It seems that the hazards will only flash the indicators on both sides of the vechicle if the indicator stalk on the column is put in the turn left position. If the stalk is in the neutral position and I turn the hazard light switch on only the right hand side will flash. I presume that is a indicator stalk/ hazard switch issue rather than relay etc . Also when the stalk is used to operate the indicators normally they work fine.
Before I go delving into the wiring I thought it was worth asking, plus I have searched for similar issues with most people suggesting the hazard switch could be at fault.
Cheers 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2002 Dax Rush 3.9 V8
2012 Audi A3 tdi
2020 Renault Kangoo electric
Post #624217 14th May 2017 11:22pm
Terryt
Morning mate I'm no expert ..I have had occasional issues check the wire connectors at the rear of the hazard switch are fully pushed home they do have a habit of working lose.
Terry
Post #624234 15th May 2017 8:19am
lb73
Wales
Cheers Terry, will give that a look later, plus if it needs replacing I think may have a spare switch floating round in the garage. 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #624248 15th May 2017 10:11am
Procta
id say its the hazard switch, be very wary of cheep replacement ones, I thought was a lucas part and it wasn't, after it started causing all 4 lights to flash if I engaged left or right with the stalk. I did have a bit of a fiddle with the socket at the back of it, which corrected it, but I found a proper lucas part and swopped if over. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #624889 17th May 2017 4:57pm
lb73
Wales
Thanks Procta will give the hazard switch a closer look, found some useful info via this link as well : https://forums.lr4x4.com/topic/25376-hazar...diagnosis/ 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #624957 17th May 2017 8:50pm
lb73
Wales
Well it was the the hazard switch, just fitted a new Lucas one and everything works as it should. Thanks again. 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #625419 19th May 2017 4:29pm
gilarion
Deleted as Posted in wrong thread Embarassed For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #625422 19th May 2017 4:42pm
Fatbaron
Superb timing for me. The link is fantastic help!
Post #625703 21st May 2017 6:41am
